I was wondering if somebody could tell me what int (*k)(int) notation means in c?
Thanks
Thanks
Code: [Select]int (*k)(int)
In what context?
That looks like a function prototype declaration that declares that there is a function that takes an int and returns an int, and that something is to take a pointer to that function.
As far as I know, k is a pointer to a function that takes and integer as argument and returns an integer.
The below gives a (quite useless in this case) example how it can be used.
int (*k)(int);
int myFunc1(int i)
return i * i;
int myFunc2(int i)
return i + i;
k = myFunc1;
Serial.print("k=myFunc1; result of k(3): "); Serial.println(k(3));
k = myFunc2;
Serial.print("k=myFunc2; result of k(3): "); Serial.println(k(3));
The strength is that you can use one function call ( k(3) ) to achieve different results.
