I understand what baud rate is, but I am trying to find out if there is ever a reason to use a lower baud rate (9600) vs. a higher baud rate (115200). Assuming the devices that the data is being transferred between are capable of the higher speed (115200) why would anyone ever use a lower baud rate? I see many sketch examples that by default set the baud rate to 9600 and it makes me think there is a reason why people are using the lower rate. Is the data more reliable at lower baud rates, less prone to communication errors?
If you have crummy cabling, or long distances, poor grounding, noisy environment, then slower baud rates can give more reliable results. Slower also uses less power as CMOS power consumption is switching frequency dependent.
If the serial comm's are buffered first, so that RS232 type levels (+/- 3 to +/-12V, one wire for send, one for receive, plus Gnd) or RS485 type signals (+/-3V, but with 2 wires for sending, 2 for receiving, plus Gnd) than higher speeds and longer distances can be supported more reliably.
I do a fair number of projects with XBees and I always use 115200 baud if the MCU clock is 16MHz, and 57600 if the clock is 8MHz. My thinking is the less time spent managing communications, the better, and more time to do other things, although due to buffering etc., it probably makes precious little if any difference in my projects. But that's just the way I think.
because it is used in so many samples
because it is one of the basic speeds of the original VT52 terminal
because it is the most supported
note that in digital communication 1 baud == 1 bit per second and in analog communication 1 baud == 1 discrete signal.
So an analog line that communicates with 16 different voltages can fit 4 bits of info per voltage. A 1000 baud line would allow 4000 bits.
