I was having issues withe the IDE crashing on my MAC so decided to take the advice of @horace to completely uninstall and do a fresh install of the IDE. I carried out the uninstall as per the following instructions:
1. Remove the Application
- Ensure the Arduino IDE is completely closed (press Command + Q to quit, or Force Quit if it's frozen).
- Open Finder and go to your Applications folder.
- Locate Arduino or Arduino IDE and drag it to the Trash.
- Empty your Trash. [1, 2, 3]
2. Delete Residual Configuration and Support Files
Arduino IDE stores your preferences, board packages, and user data in hidden system folders. To delete them:
- Open Finder, click Go in the top menu bar, and select Go to Folder... (or press Command + Shift + G).
- Type or paste the following paths one by one and delete the associated Arduino folders or files if they exist:
- ~/Library/Arduino15 (Contains installed boards, cores, and libraries)
- ~/Library/Preferences/cc.arduino.ide.plist or cc.arduino.ide2.plist
- ~/Library/Saved Application State/cc.arduino.ide.savedState
- ~/Library/Application Support/arduino-ide
- ~/Library/Caches/cc.arduino.ide
3. Remove Your Sketchbook (Optional)
If you want to remove your personal sketches and downloaded libraries permanently, they are kept in a separate folder.
- Go to ~/Documents/Arduino and delete this folder. (Note: Only do this if you are sure you do not want to save your past projects).
4. Remove the Arduino Cloud Agent (Optional)
If you also installed the web-based Arduino Cloud Agent, you need to remove it separately:
- Go to the Applications folder.
- Move ArduinoCloudAgent or ArduinoCreateAgent to the Trash and empty it.
I then reinstalled Arduino IDE, Boards and most Libraries as some I could not find using the Libraries manager. The ones I could not find were:
ansiTest
Bridge
MikroMatrix
URTouch
UTFT
VarSpeedServo
That is what the folders were called from the old install, any ideas on the missing Libraries. Also I am assuming it will be safe enough to import my Sketches again?
I was under the impression that this would delete everything and the install would be completely fresh
The IDE takes at least 10 times as long to open up as it did before - 58 seconds, and the additional boards URLs was still in the preferences, which I found a bit odd. Other than the instructions above, have I missed anything?
I have uninstalled again and will wait on advice or any pointers to check before I install again. One additional question, do I install the Apple Silicon version of IDE 2.3.10 or do I stick with the normal version
