unipolar stepper question
Hello! I recently acquired a pair of 5v 5 wire unipolar steppers. I am trying to test them to maybe implement them in the future in a plotter or laser etch project.
I have an adafruit motor shield, external 5v power supply, and I cannot get the demo code StepperTest to function properly.
There are, as I mentioned earlier, 5 wires
1 A Blue
2 B Pink
3 C Yellow
4 D Orange
5 E Red (midpoint)
The way I understand the wiring, 2&4 and 3&1 are the coil pairs.
Every combo I have tried produces only jitters, no rotation.
Any help would be awesome.
thanks
-e
maybe try lower or higher speed
Controlling the electromagnet intensity through arduino;
Check that this is correct with a meter.
Check that each coil is being energised by disconnecting on coil and seeing if you still get the feel the remaining one is being pulses. Then try pulsing it slower.
Hello again!
Thanks for the speed tip. I uploaded the example and I guess had no idea how slow and finite 10rpm and 100 steps was.(actually moving although a slow and insignificant amount)
Oops and thanks.
-e
So searching this forum I stumbled upon a thread that pointed out the steppers I own (28BYJ-48 5V) are 64 steps with 1/64 reduction.
So I changed the adafruit StepperTest code:
AF_Stepper motor(64, 2);
and then 2048 steps gives one rotation not the 4096 someone indicated.
Can anyone demystify this for me?
-e
Dear -e,
I made the same obervation when controlling the motor from an arduino program example. Maybe differences in coil addressing (microstepping vs. normal stepping)? In the datasheet http://www.yoonitrading.co.kr/doc/step-geared-fulling/(10)28BYJ48-12-300-01.pdf, I noticed a sequence of 8 triple signals applied across the 4 leads. The arduino stepper library seems to address 2 coils at a time, what I conclude from some LEDs attached to the ULN2003 driver module I'm using.
Anyway, it runs quite smoothly, especially for that price and weight :slight_smile:
Can you make a suggestion about how to connect the motor mechanically to something?
/Wo
You need a shaft coupler. There are several in this project:-
http://www.thebox.myzen.co.uk/Hardware/CNC_Conversion.html
Agreed. These cheap steppers are the only ones I currently own and are worlds smoother, quieter, and lighter than servos in my "quiver". Thanks for replies!!
-e
Hi
Just for help others like me that have get here from google.
If you just change the sequence in Arduino Stepper Examples Stepper myStepper(stepsPerRevolution, 8,9,10,11); to Stepper myStepper(stepsPerRevolution,8,10,11,9); this motor will work.
This is just the same as swapping the wires over. In other words you had it wired up wrong in the first place.
