If you need for your projects a AC MAINS Dimmer Board that can be used without any hassle and any extra overhead from the Phase Control and Zero Crossing Detection functions on your Arduino/ESP/STM/etc MCU then this is the board that you are looking for:
The MPDMv4, is a new generation of AC MAINS Dimmer drivers that have some unique characteristics as:
all the required functions onboard :
Phase control
Zero Crossing detection
Isolated MAINS
Voltage controlled unit, so you can drive it with you MCU, PWM, DAC, even a simple voltage divider with a 10k potentiometer on the VCNT input pin is enough to drive it!
build with safety in mind
-deadly simple to use. See code below:
Fading
This example shows how to fade a standard 100W 240VAC lightbulb using the MPDMv4 Driver
and the analogWrite() function.
The circuit:
VCNT attached from digital pin 3 to ground.
On the putput pin use also a 100-200u electrolitic cap for PWM smoothing.
Created 1 Nov 2008
By David A. Mellis
modified 30 Aug 2011
By Tom Igoe
modified 14 Apr 2016
by TJ for the MPDMv4 - AC MAINS Power Dimmer Driver
more details at:
http://www.esp8266-projects.com/2016/04/mpdmv4-mains-dimmerswitch.html
This example code is in the public domain.
http://arduino.cc/en/Tutorial/Fading
int VCNT = 3; // MPDMv4 Voltage Control Pin (VCNT) connected to Arduino PIN3
// initialize the VCNT pin as an output:
pinMode(VCNT, OUTPUT);
// fade in from min to max in increments of 5 points:
for(int fadeValue = 0 ; fadeValue <= 190; fadeValue +=5) {
// sets the value (range from 0 to 190): MPDMv4 Calibrated range
analogWrite(VCNT, fadeValue);
// wait for 100 milliseconds to see the dimming effect
delay(100);
// fade out from max to min in increments of 5 points:
for(int fadeValue = 190 ; fadeValue >= 0; fadeValue -=5) {
delay(100);
Using a Serial Input for the Dim Value:
AC MAINS Dimmer - MPDMv4
Demonstrates the sending data from the computer to the Arduino board,
in this case to control the brightness of a standard 100W 240VAC lightbulb using the MPDMv4 Driver
It's using the Serial parseInt() function for interactive Serial Data Input.
The circuit:
On the output pin connect also a 100-200u electrolitic cap for PWM singnal smoothing.
Serial connection to Processing, Max/MSP, or another serial application
created 2006
by David A. Mellis
by Tom Igoe and Scott Fitzgerald
more details at:
http://www.arduino.cc/en/Tutorial/Dimmer
// initialize the serial communication:
byte brightness;
// check if data has been sent from the computer:
if (Serial.available()) {
// read the most recent byte -> range from 0 to 190 : MPDMv4 Calibrated range
brightness = Serial.parseInt();
Serial.print("Command received : ");
Serial.println(brightness);
// set the brightness -> range from 0 to 190 : MPDMv4 Calibrated range
analogWrite(VCNT, brightness);
Arduino Examples are available also on GitHub:
MPDMv4 GitHub Repository
Below is a short example of how easy is to build a WIFI Dimmer unit with a ESP8266 Module and a Universal AC MAINS Dimmer Driver like the MPDMv4:
And the realated articles, explaining in more details about:
--------------------------------------------------- DISCLAIMER --------------------------------------------------
WARNING!! You will play with LIVE MAINS!! Deadly zone!!
If you don't have any experience and are not qualified for working with MAINS power I will not encourage you to play arround!. The author take no responsibility for any injury or death resulting, directly or indirectly, from your inability to appreciate the hazards of household mains voltages.
The circuit diagrams are as accurately as possible, but are offered with no guarantees whatsoever.
There is no guarantee that this design meets any Rules which may be in force in your country so please check before your local rules/regulations.
Creative Commons License
