A new version of AC MAINS Dimmer drivers that have some unique characteristics as:
- all the required functions onboard, for a smooth AC Dimming experience (Phase control, Zero Crossing detection, isolated MAINS, isolated Phase detection
AND
in the same time is reducing down to zero the added overhead on your Arduino/ESP/whaterver MCU/application processor by the time/resources consuming intensive phrase control and Zero crossing detection functions.
- it is voltage control unit, so you can drive it with you Arduino, ESP, STM32 MCU, PWM, DAC, etc even a simple voltage divider with a 10k potentiometer on the VCNT input pin is enough to drive it!
A short example of how easy is to build a WIFI Dimmer unit with a ESP8266 Module and a Universal AC MAINS Dimmer Driver like the MPDMv4:
And the realated articles, explaining in more details about:
Arduino IDE code example (yes, it is THAT simple!), using Serial Input for reading Brightness values and PWM with a simple RC filter for VCNT:
int VCNT = 3; // MPDMv4 Voltage Control Pin (VCNT) connected to Arduino PIN3
// initialize the serial communication:
// initialize the VCNT pin as an output:
pinMode(VCNT, OUTPUT);
byte brightness;
// check if data has been sent from the computer:
if (Serial.available()) {
// read the most recent byte -> range from 0 to 190 : MPDMv4 Calibrated range
brightness = Serial.parseInt();
Serial.print("Command received : ");
Serial.println(brightness);
// set the brightness -> range from 0 to 190 : MPDMv4 Calibrated range
analogWrite(VCNT, brightness);
GitHUB Link : MPDMv4 Examples
Youtube Video Tutorial: how to drive a MPDMv4 AC Dimmer Board with your Arduino:
