Hi i an looking for universal battery holder that mounts on PCB. I can only find chargers in this form but not only 1 slot holder. I am attaching an image.
Thanks!
Thanks!
Do you see anything in this Mouser search list ?
https://www.mouser.ch/c/power/battery-holders-clips-contacts/?number%20of%20batteries=1%20Battery&termination%20style=PCB
No..
So - why do you want, and what do you mean, by a universal battery holder? ![]()
Sorry about that.
So it can fit battery cells from AAA to 18650.
HI,
What is wrong with the device you showed in your first post.
It has leads to connect to a pcb and you can glue the casing to the PCB?
Gluing with that surface area would probably be better than a couple of solder joints.
What is the application?
Thanks.. Tom...
Hello
Make your own design and print it.
At university we are making NFC battery capacity meter for Christmas presents, so we need 300 holders for battery... So printing is not an option
. Tom i am thinking of buying that cheap chargers from aliexpress and disassembly it.
What if you buy a cheap holder and replace one side with a spring?
You will need some sort of crimping tool to terminate both ends of the spring.
You may find useful hardware at Keystone Electronics, www.keyelco.com.
Maybe you could look at a technique that doesn’t require a battery “holder”.
There may be abetter way but, for example, a pen with a pointer and lead. Look around the market and see what others sell.
If you want 300, design and get it printed by an outside company
