Hi, so I'm building a water temperature measuring device for a school project and I'm trying to combine 2 pre existing pieces of code and I've gotten to a point where no matter what I do I cannot seem to get passed this one line (17) I've spent now 2 days looking for help and I finally decided to come to this forums page.
Here is my code
const int hot = 87; //set hot parameter
const int cold = 75; //set cold parameter
pinMode(A0, INPUT); //ThermistorPin
pinMode(2, OUTPUT); //blue
pinMode(3, OUTPUT); //green
pinMode(4, OUTPUT); //red
int ThermistorPin = analogRead(A0);
int Vo;
float R1 = 10000;
float logR2, R2, T;
float c1 = 1.009249522e-03, c2 = 2.378405444e-04, c3 = 2.019202697e-07;
A0 = analogRead(ThermistorPin);
R2 = R1 * (1023.0 / (float)Vo - 1.0);
logR2 = log(R2);
T = (1.0 / (c1 + c2*logR2 + c3*logR2*logR2*logR2));
T = T - 273.15;
T = (T * 9.0)/ 5.0 + 32.0;
Serial.print("Temperature: ");
Serial.print(T);
Serial.println(" F");
if (tempF < cold) { //cold
digitalWrite(2, HIGH);
digitalWrite(3, LOW);
digitalWrite(4, LOW);
Serial.println(" It's Cold.");
else if (tempF >= hot) { //hot
digitalWrite(2, LOW);
digitalWrite(4, HIGH);
Serial.println(" It's Hot.");
else { //fine
digitalWrite(3, HIGH);
Serial.println(" It's Fine.");
Here is the error message that popped up with it
C:\Users\DRAGON~1\AppData\Local\Temp\arduino_modified_sketch_585364\Digital_Inputs.ino: In function 'void loop()':
Digital_Inputs:17:32: error: assignment of read-only variable 'A0'
Digital_Inputs:28:5: error: 'tempF' was not declared in this scope
C:\Users\DRAGON~1\AppData\Local\Temp\arduino_modified_sketch_585364\Digital_Inputs.ino:28:5: note: suggested alternative: 'memcpy'
memcpy
Digital_Inputs:46:1: error: expected '}' at end of input
exit status 1
If there is nothing you can do with this can you at least help me get going in the right direction? Thank you for taking the time to read this.
