Thanks to Gemini AI and some side ways thinking. its very easy.
Hints at beginning. full instructions follow at end.
Be very careful with Partition details!
hi Im running my unoQ with 17gb free space
please forgive spelling im autistic
first create old home partition copy every thing maintaining permissions
make sure linux isnt looking at the old home partition
fstab?
rename the new home folder to home
use fdisk note partition names and sizes delete home
delete root then make a partition the start of root and the end of home
then use "resize??" command to tidy up
doing it this way you loose nothing but might need to delete stuff to make room to preserve any work in home. you can put all that back in your 18gb
i can try to be more detailed if you like i used gemini to tell me exactly what to type in terminal took about twenty min
the great thing is this way you dont lose anything. i tried armbian for the unoQ
that gave me the idea gemini just told me what to type. try programming when you cant type or spell but autistic people can be very determined! it uses gpt so no need to worry about primary partitions
critical you must make sure linux doesnt look for home partition
**INSTRUCTIONS **
You might need to install some commands
Phase 1: The "Lifeboat" (Data Migration)
Before deleting anything, you must move your home files to the root partition.
Create a temporary landing zone:
sudo mkdir /home_new
Mirror your files (Preserving Permissions):
sudo rsync -avxHAWXS --numeric-ids /home/ /home_new/
Verify: Make sure your files are in /home_new before proceeding.
Phase 2: Breaking the Link
You must tell Linux to stop looking for the separate hardware partition.
Edit the Paper Trail:
sudo nano /etc/fstab
The "Kill Switch": Find the line that mentions /home/arduino and put a # at the very start of that line. Save and exit.
The Swap:
sudo umount /home
sudo mv /home /home_old
sudo mv /home_new /home
Reboot: Your system is now running entirely off the root partition.
Phase 3: The Surgical Expansion
Now you delete the "wall" and stretch the room.
Open fdisk: sudo fdisk /dev/mmcblk0
Record the Start: Type p and write down the Start Sector of your root partition (usually partition 24).
Delete: Type d and delete the old home partition number, then type d and delete the root partition number.
Recreate: Type n for a new partition.
Use the same partition number for root.
Use the exact same Start Sector you wrote down.
Hit Enter for the end sector to take the whole 20GB.
Save the Data: When asked if you want to "remove the ext4 signature," Type N (No).
Write: Type w and exit.
Phase 4: The Final Stretch
Tell the filesystem to fill the new space you just created.
Refresh: sudo partprobe
Grow: sudo resize2fs /dev/mmcblk0p24 (or your root number).
Victory: df -h should now show a glorious 19GB+ on your root.
