Hi!
I purchased a UNO R3 + wifi clone (ATmega 328p + ESP8266 8mb flash, CH340G, image attached) from a local electronics shop where the return is not allowed. I'm not able to upload code into the 328p. I'm getting the following error.
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\ASUS\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xb9
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xb9
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xb9
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xb9
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xb9
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xb9
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xb9
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xb9
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xb9
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xb9
avrdude done. Thank you.
Failed uploading: uploading error: exit status 1
Things that I checked/tried.
- CH340 Driver is installed.
- DIP switches 3 and 4 only ON others OFF.
- Pressing reset (and ESP reboot) till it starts uploading.
- Loop Back test passed (hence USB to TTL serial is working)
- Bootloader is fine (checked by connecting LED to 13 and GND).
- Burned the bootloader from another UNO (To make sure the bootloader is not faultly)
I haven't tried anything with the ESP as I don't need it now. The RX and TX are constantly blinking but not completely (kind of low-voltage LED) and L is not at all blinking (once in a while in the low-voltage kind of state when I'm pressing RESET).
Nothing helped. What could be the source of the issue? If anyone with a similar issue has a solution, please help me as well.
Thanks in advance.
