Hello all, I'm new to the world of MCU's so bear with me please.
I'm trying to control a laser galvo with the R4 DAC pin. So far I've set up an NE5532 as non-inverting with +-15v input and 5v signal, 2.5v reference and simple feedback resistance. The circuit swings from +10 to -10 quite nicely when using a 5vdc power supply, but when I use the DAC pin everything goes haywire.
I've tried analogReadResolution and analogWriteResolution in 8, 10 and 12 bit, mapped a slide pot to A0 in order to vary output voltage from 0 to 5v but the DAC output signal is very noisy. I've done away with the pot and set the DAC output to a range of steady values yet the problem persists.
My Arduino question is - is the arduino DAC just noisy in general, or am I missing some important code?
Do I need to filter the DAC output? I'd have thought it would be a clean signal considering theres no waveform involved.
Here's my sketch, as simple as it is. Thanks in advance
#include "analogWave.h"
analogWriteResolution (12);
analogReadResolution (12);
int qq = analogRead (A5);
int ww = map (qq, 0, 4095, 0, 4095);
analogWrite (DAC, ww);
