I just got a uno r4 wifi board from sparkfun. I also got a usbc to usb cable from them. At foirst everything worked. COM3 was the new board.
After a number of successful downloads, com3 went away (in tools, port. I got a 'can not upload 'message from the ide when i went to compile and uploiad amy sletch. When I reset the board, the yallow led blinkls twice. If I press the reset twice, the boaed has a slow yellow led lit. Com 3 does no longer show up in the device manager or the tools /port:
I am running windows 10.
I understand the usb port goes through the esp board. Therer is a jumper on the back of the card that routes usb directly to the r4 processor. I
Befortre I go and attempt to solder this jumper ti see if the main processor program is at fault I am looking for wisdom.
First, double tap the reset button fast and check the status of the onboard "L" LED. If the onboard LED fade in and out slowly (pulsating), upload an example sketch (Blink LED) from the IDE to the board. This should reset your board.
