I'm trying to use UNO+WiFi R3 ATmega328P+ESP8266 that I followed the tutorial from here, and I'm trying to print something out from the ESP8266 chip, but nothing showed up when I set the number 5 and 6 dips on. I also have uploaded the script by setting the number 5, 6, and 7 on.
Also, when I'm trying to send some keys to the Serial Monitor when the number 5 and 6 dips is on, it threw an exception:
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
at processing.app.Serial.write(Serial.java:254)
at processing.app.Serial.write(Serial.java:274)
at processing.app.SerialMonitor.send(SerialMonitor.java:122)
at processing.app.SerialMonitor.lambda$new$1(SerialMonitor.java:66)
at javax.swing.JTextField.fireActionPerformed(JTextField.java:508)
at javax.swing.JTextField.postActionEvent(JTextField.java:721)
at javax.swing.JTextField$NotifyAction.actionPerformed(JTextField.java:836)
at javax.swing.SwingUtilities.notifyAction(SwingUtilities.java:1668)
at javax.swing.JComponent.processKeyBinding(JComponent.java:2882)
at javax.swing.JComponent.processKeyBindings(JComponent.java:2929)
at javax.swing.JComponent.processKeyEvent(JComponent.java:2845)
at java.awt.Component.processEvent(Component.java:6316)
at java.awt.Container.processEvent(Container.java:2239)
at java.awt.Component.dispatchEventImpl(Component.java:4889)
at java.awt.Container.dispatchEventImpl(Container.java:2297)
at java.awt.Component.dispatchEvent(Component.java:4711)
at java.awt.KeyboardFocusManager.redispatchEvent(KeyboardFocusManager.java:1954)
at java.awt.DefaultKeyboardFocusManager.dispatchKeyEvent(DefaultKeyboardFocusManager.java:835)
at java.awt.DefaultKeyboardFocusManager.preDispatchKeyEvent(DefaultKeyboardFocusManager.java:1103)
at java.awt.DefaultKeyboardFocusManager.typeAheadAssertions(DefaultKeyboardFocusManager.java:974)
at java.awt.DefaultKeyboardFocusManager.dispatchEvent(DefaultKeyboardFocusManager.java:800)
at java.awt.Component.dispatchEventImpl(Component.java:4760)
at java.awt.Window.dispatchEventImpl(Window.java:2746)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:760)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:84)
at java.awt.EventQueue$4.run(EventQueue.java:733)
at java.awt.EventQueue$4.run(EventQueue.java:731)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:730)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
My ESP8266 setup:
My ESP8266 code:
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
// WiFi CREDENTIALS
const char *ssid = "myssid";
const char *password = "mypassword";
Serial.print("Connect to: ");
Serial.println(ssid);
void loop(){
WiFi.begin(ssid, password);
if (WiFi.status() == WL_CONNECTED) {
Serial.print("From ESP Connected!");
else {
Serial.print("From ESP Not Connected!");
I recently tried changing the baud rate from 9600 to 115200, and went to 115200 baud's Serial Monitor, also nothing. But for 9600 baud's Serial Monitor, it printed garbage value.
Thanks in advance for helping!
