saffer
January 16, 2021, 9:37pm
1
Hi All,
I'm not the most brilliant Arduino programmer, and still getting to grips with a lot of the code.
Been playing with the millis() function.
I have two variables configured as unsigned long
unsigned long PreFlowDelayMs = 0;
unsigned long currPreFlowMs = millis();
Part of my code which is in a timing loop is supposed to take the value of currPreFlowMs and essentially assign that value to PreFlowDelayMs .
As in the section of code.
PreFlowDelayMs = currPreFlowMs;
Tracing the code, I note that the value of currPreFlowMs is never assigned to PreFlowDelayMs .
Before I post a lot of code, maybe someone has come across this and has an answer.
Thanx.
Are you perhaps somehow imagining that currPreFlowMs somehow gets magically updated each time mullis changes? It does not. You have to explicitly update it whenever necessary.
Or maybe you've got a scope issue.
Post. The. Code.
Really? Try examining it immediately afterwards:
Serial.println(PreFlowDelayMs);
Serial.println(currPreFlowMs);
If neither values gets printed, you just messed up somewhere and your code skips the lines entirely.
system
Closed
May 16, 2021, 9:57pm
6
