Hi all,
I have created a system but when viewing the serial out put I get "No more addresses" at the end of the serial output. I have had a look through my code but I cannot find the statement being put at the end only at front of the program where if the sensor is not found then this statement is displayed.
I will attach my program, just to clarify The highlighted text is what I do not want in the serial output (see capture.png).
Sorry if I've worded it awkwardly!
Here is my code as requested
#include <U8glib.h>
#include <OneWire.h> //temperature lib
OneWire ds(10); // declare on pin 10 with a 4.7 ohm resistor
U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_NONE|U8G_I2C_OPT_DEV_0); // I2C / TWI
//start serial connection
//configure pin2 as an input and enable the internal pull-up resistor
pinMode(A5, INPUT); //Water Sensor
pinMode(13, OUTPUT);
pinMode(9, OUTPUT); //Buzzer
beep(50);
if ( u8g.getMode() == U8G_MODE_R3G3B2 ) {
u8g.setColorIndex(255); // white
else if ( u8g.getMode() == U8G_MODE_GRAY2BIT ) {
u8g.setColorIndex(3); // max intensity
else if ( u8g.getMode() == U8G_MODE_BW ) {
u8g.setColorIndex(1); // pixel on
else if ( u8g.getMode() == U8G_MODE_HICOLOR ) {
u8g.setHiColorByRGB(255,255,255);
byte i;
byte present = 0;
byte type_s;
byte data[12];
byte addr[8];
float celsius, fahrenheit;
//read the sensor value into a variable
int waterVal = analogRead(A5); //read the waterlevel and put it to an int
Serial.print("The water value is "); //print out the value of the sensor
Serial.print(waterVal);
if (waterVal > 570) { //if the water value is above 700 the led comes on and buzzer beeps
highwater();
digitalWrite(13, LOW);
if ( !ds.search(addr))
Serial.println(F("No more addresses."));
ds.reset_search();
delay(250);
return;
if (OneWire::crc8(addr, 7) != addr[7])
Serial.println("CRC is not valid!");
return;
// the first ROM byte indicates which chip
switch (addr[0])
case 0x10:
Serial.println(F(" Chip = DS18S20")); // or old DS1820
type_s = 1;
case 0x28:
Serial.println(F(" Chip = DS18B20"));
type_s = 0;
case 0x22:
Serial.println(F(" Chip = DS1822"));
type_s = 0;
default:
Serial.println(F("Device is not a DS18x20 family device."));
return;
ds.reset();
ds.select(addr);
ds.write(0x44, 1); // start conversion, with parasite power on at the end
delay(1000); // maybe 750ms is enough, maybe not
// we might do a ds.depower() here, but the reset will take care of it.
present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
Serial.print(F(" Data = "));
Serial.print(present, HEX);
Serial.print(F(" "));
for ( i = 0; i < 9; i++)
{ // we need 9 bytes
data[i] = ds.read();
Serial.print(data[i], HEX);
Serial.print(" CRC=");
Serial.print(OneWire::crc8(data, 8), HEX);
// Convert the data to actual temperature
// because the result is a 16 bit signed integer, it should
// be stored to an "int16_t" type, which is always 16 bits
// even when compiled on a 32 bit processor.
int16_t raw = (data[1] << 8) | data[0];
if (type_s) {
raw = raw << 3; // 9 bit resolution default
if (data[7] == 0x10) {
// "count remain" gives full 12 bit resolution
raw = (raw & 0xFFF0) + 12 - data[6];
byte cfg = (data[4] & 0x60);
// at lower res, the low bits are undefined, so let's zero them
if (cfg == 0x00) raw = raw & ~7; // 9 bit resolution, 93.75 ms
else if (cfg == 0x20) raw = raw & ~3; // 10 bit res, 187.5 ms
else if (cfg == 0x40) raw = raw & ~1; // 11 bit res, 375 ms
//// default is 12 bit resolution, 750 ms conversion time
celsius = (float)raw / 16.0;
// fahrenheit = celsius * 1.8 + 32.0;
Serial.print(F(" Temperature = "));
Serial.print(celsius);
Serial.print(F(" Celsius, "));
// Serial.print(fahrenheit);
// Serial.println(" Fahrenheit");
void beep(unsigned char delayms)
tone(9,254,2000);
void highwater()
digitalWrite(13, HIGH);
beep(40000);
Here is the output:
The water value is 0
Chip = DS18B20
Data = 1 50 1 4B 46 7F FF 10 10 49 Temperature = 21.00 Celsius, The water value is 0No more addresses.
Chip = DS18B20
Dementia_patient_Sensor.ino (3.88 KB)
