Hi, I'm working with an ESP12F, and I wanted to update the firmware using a URL. I found a code on a website, which was written for an ESP32, which updates using the IP address. So I changed the code to fit for an ESP8266, and also to update using a URL. The original code first directed to a page where you need to enter a password, and then was directed to a page where you can upload, and it also shows the uploaded percentage. But after I changed the code, where I could upload using a URL instead of using the IP, I'm being directed to a whole different page. Really appreciate if someone could point out to what I'm doing wrong and advice me on what to be done.
The original code:
* OTAWebUpdater.ino Example from ArduinoOTA Library
* Rui Santos
* Complete Project Details https://randomnerdtutorials.com
#include <WiFi.h>
#include <WiFiClient.h>
#include <WebServer.h>
#include <ESPmDNS.h>
#include <Update.h>
const char* host = "esp32";
const char* ssid = "REPLACE_WITH_YOUR_SSID";
const char* password = "REPLACE_WITH_YOUR_PASSWORD";
WebServer server(80);
* Login page
const char* loginIndex =
"<form name='loginForm'>"
"<table width='20%' bgcolor='A09F9F' align='center'>"
"<tr>"
"<td colspan=2>"
"<center><font size=4><b>ESP32 Login Page</b></font></center>"
"<br>"
"</td>"
"<br>"
"<br>"
"</tr>"
"<td>Username:</td>"
"<td><input type='text' size=25 name='userid'><br></td>"
"</tr>"
"<br>"
"<br>"
"<tr>"
"<td>Password:</td>"
"<td><input type='Password' size=25 name='pwd'><br></td>"
"<br>"
"<br>"
"</tr>"
"<tr>"
"<td><input type='submit' onclick='check(this.form)' value='Login'></td>"
"</tr>"
"</table>"
"</form>"
"<script>"
"function check(form)"
"if(form.userid.value=='admin' && form.pwd.value=='admin')"
"window.open('/serverIndex')"
"else"
" alert('Error Password or Username')/*displays error message*/"
"</script>";
* Server Index Page
const char* serverIndex =
"<script src='https://ajax.googleapis.com/ajax/libs/jquery/3.2.1/jquery.min.js'></script>"
"<form method='POST' action='#' enctype='multipart/form-data' id='upload_form'>"
"<input type='file' name='update'>"
"<input type='submit' value='Update'>"
"</form>"
"<div id='prg'>progress: 0%</div>"
"<script>"
"$('form').submit(function(e){"
"e.preventDefault();"
"var form = $('#upload_form')[0];"
"var data = new FormData(form);"
" $.ajax({"
"url: '/update',"
"type: 'POST',"
"data: data,"
"contentType: false,"
"processData:false,"
"xhr: function() {"
"var xhr = new window.XMLHttpRequest();"
"xhr.upload.addEventListener('progress', function(evt) {"
"if (evt.lengthComputable) {"
"var per = evt.loaded / evt.total;"
"$('#prg').html('progress: ' + Math.round(per*100) + '%');"
"}, false);"
"return xhr;"
"success:function(d, s) {"
"console.log('success!')"
"error: function (a, b, c) {"
"</script>";
* setup function
void setup(void) {
// Connect to WiFi network
WiFi.begin(ssid, password);
Serial.println("");
// Wait for connection
Serial.print(".");
Serial.println("");
Serial.print("Connected to ");
Serial.println(ssid);
Serial.print("IP address: ");
/*use mdns for host name resolution*/
if (!MDNS.begin(host)) { //http://esp32.local
Serial.println("Error setting up MDNS responder!");
while (1) {
Serial.println("mDNS responder started");
/*return index page which is stored in serverIndex */
server.on("/", HTTP_GET, []() {
server.sendHeader("Connection", "close");
server.send(200, "text/html", loginIndex);
server.on("/serverIndex", HTTP_GET, []() {
server.send(200, "text/html", serverIndex);
/*handling uploading firmware file */
server.on("/update", HTTP_POST, []() {
server.send(200, "text/plain", (Update.hasError()) ? "FAIL" : "OK");
ESP.restart();
HTTPUpload& upload = server.upload();
if (upload.status == UPLOAD_FILE_START) {
Serial.printf("Update: %s\n", upload.filename.c_str());
if (!Update.begin(UPDATE_SIZE_UNKNOWN)) { //start with max available size
Update.printError(Serial);
} else if (upload.status == UPLOAD_FILE_WRITE) {
/* flashing firmware to ESP*/
if (Update.write(upload.buf, upload.currentSize) != upload.currentSize) {
} else if (upload.status == UPLOAD_FILE_END) {
if (Update.end(true)) { //true to set the size to the current progress
Serial.printf("Update Success: %u\nRebooting...\n", upload.totalSize);
server.begin();
void loop(void) {
server.handleClient();
delay(1);
The code after the changes I made:
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
#include <ESP8266HTTPUpdateServer.h>
const char* host = "esp8266WebUpdate";
const char* ssid = "_fonseca_mir";
const char* password = "ilovefrench248ch";
ESP8266WebServer server(80);
ESP8266HTTPUpdateServer httpUpdater;
* Login page
"<tr>"
"<td colspan=2>"
"<br>"
"</td>"
"<br>"
"<br>"
"</tr>"
"</tr>"
"<br>"
"<br>"
"<tr>"
"<br>"
"<br>"
"</tr>"
"<tr>"
"</tr>"
"</table>"
"</form>"
"<script>"
"else"
"</script>";
* Server Index Page
"</form>"
"<script>"
" $.ajax({"
"url: '/update',"
"type: 'POST',"
"data: data,"
"xhr: function() {"
"}, false);"
"return xhr;"
"</script>";
* setup function
void setup(void) {
Serial.println("");
Serial.print(".");
MDNS.begin(host);
httpUpdater.setup(&server);
server.begin();
MDNS.addService("http", "tcp", 80);
Serial.printf("HTTPUpdateServer ready! Open http://%s.local/update in your browser\n", loginIndex);
while (1) {
ESP.restart();
/* if (!Update.begin(UPDATE_SIZE_UNKNOWN)) { //start with max available size
else {
server.begin();
void loop(void) {
MDNS.update();
delay(1);
Thanks in advance!
Shainy
