So, this error is a new one to me. It appears to be uploading, the TX/RX LEDs blink for a little bit, then the stop and the IDE just sits there saying "Uploading" and eventually it says "An error occured while uploading the sketch".
I'm assuming it's an issue with my sketch, which is quite large. It uses 98% of the program space, but I don't know why that would break anything. I've tried this on two computers. I've disconnected all shields from the board for the upload, nothing helps.
I'm using 1.8.5, and I've attached the sketch in case anybody has any ideas or pointers here.
Has anyone ever seen this before? Thanks!
EDIT: If you actually try to compile it, you'll need the FemtoCow SPIRAM24 library, and the Adafruit_GFX and Adafruit_TFTLCD libraries.
apple2.zip (24.5 KB)
Here's what it gives me. Same result on the other PC I tried.
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\Mike Chambers\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 3
Firmware Version: 3.3
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\MIKECH~1\AppData\Local\Temp\arduino_build_258490/apple2.ino.hex"
avrdude: writing flash (31812 bytes):
Writing | ############################################avrdude: stk500_recv(): programmer is not responding
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
I figured it out. My AVR's flash has finally started failing. Fair enough, I've had it for 7 years. I picked up a new Uno and it works fine.
There are older versions of the bootloader that have an upload limit of 30kBytes due to a bug in the bootloader code. This may also be the cause. I find it very hard to actually exceed the upload limit of 10,000 writes
https://code.google.com/archive/p/arduino/issues/380
