Re: An error occurred while uploading the sketch.
Arduino: 1.8.7 (Mac OS X), Board: "Arduino/Genuino Uno"
Sketch uses 930 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
/private/var/folders/f2/ch_dg2l927x1tz23hxm87lhc0000gn/T/AppTranslocation/0E547C32-783C-44AD-B0F5-98B38B8BF8AD/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/private/var/folders/f2/ch_dg2l927x1tz23hxm87lhc0000gn/T/AppTranslocation/0E547C32-783C-44AD-B0F5-98B38B8BF8AD/d/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.usbmodem1411 -b115200 -D -Uflash:w:/var/folders/f2/ch_dg2l927x1tz23hxm87lhc0000gn/T/arduino_build_438699/Blink.ino.hex:i
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/private/var/folders/f2/ch_dg2l927x1tz23hxm87lhc0000gn/T/AppTranslocation/0E547C32-783C-44AD-B0F5-98B38B8BF8AD/d/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/diannedavis/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbmodem1411
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
