Upload using programmer: bundled avrdude fails to verify, post upload
Ext. Programmer: Atmel ICE
Board: Arduino Uno
Arduino IDE version: 1.8.19
System: MacOS ventura
What am I trying to do?
Upload using Programmer
What's the issue?
Compiled Hex uploads, but fails to Verify and throws error in the verbose output of IDE.
Same issue for IDE 2x
It get's written, I know, as my program (blink.ino) makes the built in led blink and even if I change the duration, it get's changed.
How am I uploading the program?
Well you know, Select the programmer as Atmel Ice (AVR) , then select the board as Arduino Uno, then Hit Upload Using Programmer
What's the error?
Here's the dump:
Arduino: 1.8.19 (Mac OS X), Board: "Arduino Uno"
/Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/sdatta/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/sdatta/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/sdatta/Documents/Arduino/libraries -fqbn=arduino:avr:uno -vid-pid=0000_0000 -ide-version=10819 -build-path /var/folders/1n/b1z5c12n5xv_w78jc8xnqt186nc7wn/T/arduino_build_564701 -warnings=all -build-cache /var/folders/1n/b1z5c12n5xv_w78jc8xnqt186nc7wn/T/arduino_cache_560161 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=/Users/sdatta/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=/Users/sdatta/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=/Users/sdatta/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/Users/sdatta/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -prefs=runtime.tools.arduinoOTA.path=/Users/sdatta/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=/Users/sdatta/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -verbose /var/folders/1n/b1z5c12n5xv_w78jc8xnqt186nc7wn/T/arduino_modified_sketch_741793/Blink.ino
/Applications/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/sdatta/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/sdatta/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/sdatta/Documents/Arduino/libraries -fqbn=arduino:avr:uno -vid-pid=0000_0000 -ide-version=10819 -build-path /var/folders/1n/b1z5c12n5xv_w78jc8xnqt186nc7wn/T/arduino_build_564701 -warnings=all -build-cache /var/folders/1n/b1z5c12n5xv_w78jc8xnqt186nc7wn/T/arduino_cache_560161 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=/Users/sdatta/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=/Users/sdatta/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=/Users/sdatta/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/Users/sdatta/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -prefs=runtime.tools.arduinoOTA.path=/Users/sdatta/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=/Users/sdatta/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -verbose /var/folders/1n/b1z5c12n5xv_w78jc8xnqt186nc7wn/T/arduino_modified_sketch_741793/Blink.ino
Using board 'uno' from platform in folder: /Users/sdatta/Library/Arduino15/packages/arduino/hardware/avr/1.8.6
Using core 'arduino' from platform in folder: /Users/sdatta/Library/Arduino15/packages/arduino/hardware/avr/1.8.6
Detecting libraries used...
/Users/sdatta/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/Users/sdatta/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/Users/sdatta/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /var/folders/1n/b1z5c12n5xv_w78jc8xnqt186nc7wn/T/arduino_build_564701/sketch/Blink.ino.cpp -o /dev/null
Generating function prototypes...
/Users/sdatta/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/Users/sdatta/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/Users/sdatta/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /var/folders/1n/b1z5c12n5xv_w78jc8xnqt186nc7wn/T/arduino_build_564701/sketch/Blink.ino.cpp -o /var/folders/1n/b1z5c12n5xv_w78jc8xnqt186nc7wn/T/arduino_build_564701/preproc/ctags_target_for_gcc_minus_e.cpp
/Applications/Arduino.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /var/folders/1n/b1z5c12n5xv_w78jc8xnqt186nc7wn/T/arduino_build_564701/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/Users/sdatta/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/Users/sdatta/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/Users/sdatta/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /var/folders/1n/b1z5c12n5xv_w78jc8xnqt186nc7wn/T/arduino_build_564701/sketch/Blink.ino.cpp -o /var/folders/1n/b1z5c12n5xv_w78jc8xnqt186nc7wn/T/arduino_build_564701/sketch/Blink.ino.cpp.o
Compiling libraries...
Compiling core...
Using precompiled core: /var/folders/1n/b1z5c12n5xv_w78jc8xnqt186nc7wn/T/arduino_cache_560161/core/core_arduino_avr_uno_984314b70533ddd2c38421e3ac39c7ba.a
Linking everything together...
/Users/sdatta/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc -Wall -Wextra -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o /var/folders/1n/b1z5c12n5xv_w78jc8xnqt186nc7wn/T/arduino_build_564701/Blink.ino.elf /var/folders/1n/b1z5c12n5xv_w78jc8xnqt186nc7wn/T/arduino_build_564701/sketch/Blink.ino.cpp.o /var/folders/1n/b1z5c12n5xv_w78jc8xnqt186nc7wn/T/arduino_build_564701/../arduino_cache_560161/core/core_arduino_avr_uno_984314b70533ddd2c38421e3ac39c7ba.a -L/var/folders/1n/b1z5c12n5xv_w78jc8xnqt186nc7wn/T/arduino_build_564701 -lm
/Users/sdatta/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /var/folders/1n/b1z5c12n5xv_w78jc8xnqt186nc7wn/T/arduino_build_564701/Blink.ino.elf /var/folders/1n/b1z5c12n5xv_w78jc8xnqt186nc7wn/T/arduino_build_564701/Blink.ino.eep
/Users/sdatta/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy -O ihex -R .eeprom /var/folders/1n/b1z5c12n5xv_w78jc8xnqt186nc7wn/T/arduino_build_564701/Blink.ino.elf /var/folders/1n/b1z5c12n5xv_w78jc8xnqt186nc7wn/T/arduino_build_564701/Blink.ino.hex
/Users/sdatta/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-size -A /var/folders/1n/b1z5c12n5xv_w78jc8xnqt186nc7wn/T/arduino_build_564701/Blink.ino.elf
Sketch uses 922 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
/Users/sdatta/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/bin/avrdude -C/Users/sdatta/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -catmelice_isp -Pusb -Uflash:w:/var/folders/1n/b1z5c12n5xv_w78jc8xnqt186nc7wn/T/arduino_build_564701/Blink.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/Users/sdatta/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf"
         User configuration file is "/Users/sdatta/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : usb
         Using Programmer              : atmelice_isp
avrdude: Found CMSIS-DAP compliant device, using EDBG protocol
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : JTAG3_ISP
         Description     : Atmel-ICE (ARM/AVR) in ISP mode
         Vtarget         : 4.6 V
         SCK period      : 125.00 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
         To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "/var/folders/1n/b1z5c12n5xv_w78jc8xnqt186nc7wn/T/arduino_build_564701/Blink.ino.hex"
avrdude: writing flash (922 bytes):
Writing | avrdude: Short read, read only 0 out of 512 bytes
avrdude: jtag3_edbg_recv(): Unexpected response 0x00
avrdude: stk500v2_jtag3_recv(): error in jtagmkII_recv()
######avrdude: jtag3_edbg_send(): Unexpected response 0x81, 0x11
avrdude: jtag3_edbg_recv(): Unexpected response 0x80
######avrdude: Short read, read only 0 out of 512 bytes
avrdude: jtag3_edbg_send(): Unexpected response 0x00, 0x55
avrdude: jtag3_edbg_recv(): Inconsistent fragment number; expect 1, got 0
#######avrdude: jtag3_edbg_send(): Unexpected response 0x81, 0x00
######avrdude: jtag3_edbg_recv(): Inconsistent fragment number; expect 1, got 0
######avrdude: jtag3_edbg_recv(): Unexpected response 0x80
####### | 100% 3.13s
avrdude: 922 bytes of flash written
avrdude: verifying flash memory against /var/folders/1n/b1z5c12n5xv_w78jc8xnqt186nc7wn/T/arduino_build_564701/Blink.ino.hex:
avrdude: load data flash data from input file /var/folders/1n/b1z5c12n5xv_w78jc8xnqt186nc7wn/T/arduino_build_564701/Blink.ino.hex:
avrdude: input file /var/folders/1n/b1z5c12n5xv_w78jc8xnqt186nc7wn/T/arduino_build_564701/Blink.ino.hex contains 922 bytes
avrdude: reading on-chip flash data:
Reading | avrdude: Short read, read only 0 out of 512 bytes
avrdude: jtag3_edbg_send(): Unexpected response 0x32, 0x00
avrdude: jtag3_edbg_send(): Unexpected response 0x10, 0x55
####### | 100% 3.04s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0000
         0x80 != 0x0c
avrdude: verification error; content mismatch
avrdude: jtag3_edbg_send(): Unexpected response 0x60, 0x55
avrdude: bad response to sign-off command: 0x14
avrdude: jtag3_edbg_signoff(): unexpected response 0x80, 0x01
avrdude: jtag3_edbg_signoff(): unexpected response 0x81, 0x00
avrdude done.  Thank you.
the selected serial port
 does not exist or your board is not connected
Hardware connection to ISP header:
Correct Orientation as seen in the picture (The tab on the programming 6 pin conn is facing inwards).
What did I try next?
  • Installed avrdude (using homebrew). It's version 7.2
  • I compiled and exported the hex using arduino-cli:
arduino-cli compile -b arduino:avr:uno --build-path $(pwd)/build
  • Then Uploaded using the system's avrdude:
avrdude -catmelice_isp -pm328p -v -Uflash:w:build/blink.ino.hex:i
Result: No error, clean build and upload.
What I noticed is: avrdude bundled in Arduino IDE's is 6.something.
Also I get error to burn bootloader using ATMEL-ICE, from IDE.
Any pointers, how to update the avrdude, if that's causing the issue.
Before I go down the rabbit-hole, I thought of asking here first.
Thank you for all your help in advance.
UPDATE
I edited the programmers.txt to use the latest avrdude and not the bundled one as the one I installed via homebrew is of version 7.2 and as we already know that running avrdude (v7.2) from commandline throws no edbg error.
Steps I took:
  • Locate programmers.txt
For IDE 2.21, on macOS, it is located at:
/Users/<user_name>/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/programmers.txt
For IDE 1.8.19, on macOS, you have to right click on the Arduino app; Click Show Package Contents and navigate to:
Contents/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/programmers.txt
  • Locate programmers.txt and find the section related to Atmel-ICE (it's the last items)
    The default section has the below entries where it uses the bundled avrdude (6.xx)
atmel_ice.name=Atmel-ICE (AVR)
atmel_ice.communication=usb
atmel_ice.protocol=atmelice_isp
atmel_ice.program.protocol=atmelice_isp
atmel_ice.program.tool=avrdude
atmel_ice.program.extra_params=-Pusb
Modify it to include the externally installed avrdude (homebrew version)
atmel_ice.program.tool=/opt/homebrew/bin/avrdude
atmel_ice.program.tool.default=/opt/homebrew/bin/avrdude
atmel_ice.program.extra_params=-Pusb -C/opt/homebrew/etc/avrdude.conf
atmel_ice.program.pattern=/opt/homebrew/bin/avrdude -C/opt/homebrew/etc/avrdude.conf -v -patmega328p -catmelice_isp -Pusb -Uflash:w:{build.path}/{build.project_name}.hex:i
Restart the IDE and after selecting your correct board and programmer as Atmel-ICE (avr), either press shift+command+u or click Upload Using Programmer from the Sketch menu.
And? No error :kissing_heart:
Very hacky and hard coded for uno only process for now though. But it proves that the errors were coming because of the older avrdude version.
Any pointers on how to resolve this using the bundled avrdude version?
