Uploading code from Arduino PLC IDE
when I'm uploading code from Arduino PLC IDE, i need to double tap reset button to download code correctly. If I did not double press the reset button I get uploading error: exit status 74, DFU util fails because the device not found. When i try to download any example in Arduino IDE the DFU util works well without reseting the board. Is there anything in Arduino PLC IDE setting I can change to make it work properly without reset?
It is also work when i try to upload a sketch manualy in Arduino PLC IDE. But when I am connected to the board from PLC IDE regularry I got this error.
Thank you in advance
