Uploading Hex file programmer doesn't respond
Hi.
I'm trying to upload a hex file to Arduino Mega with command line in Fedora 23 but i got is that programmer is not responding.
The Arduino is connected i can upload code from Arduino IDE
I also tried with and Arduino Uno and the result is the same.
the file is grbl.hex to use UniversalGCodeSender to a CNC.
$ avrdude -v -patmega2560 -Uflash:w:grbl.hex:i -carduino -b 57600 -P /dev/ttyUSB0
avrdude: Version 6.1, compiled on Jun 17 2015 at 01:36:16
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/etc/avrdude/avrdude.conf"
         User configuration file is "/home/jpill/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/ttyUSB0
         Using Programmer              : arduino
         Overriding Baud Rate          : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done.  Thank you.
So, what can i am missing to upload the file?
Thanks.
Is that the mega2560? if so, needs to be -cwiring not -carduino, and 115200 baud.
For mega with atmega1280, that looks correct.
Hi DrAzzy
That made the thing, thanks for your help
avrdude -v -patmega1280 -Uflash:w:grbl.hex:i -cwiring -b 115200 -P /dev/ttyUSB0
         Using Programmer              : wiring
         Overriding Baud Rate          : 115200
         AVR Part                      : ATmega1280
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10     8    0 no       4096    8      0  9000  9000 0x00 0x00
           flash         65    10   256    0 yes    131072  256    512  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Wiring
         Description     : Wiring
         Programmer Model: AVRISP
         Hardware Version: 15
         Firmware Version Master : 2.10
         Vtarget         : 0.0 V
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e9801
avrdude: Expected signature for ATmega1280 is 1E 97 03
         Double check chip, or use -F to override this check.
