I am a newbie to arduino. I tried to uploading the code to my arduino UNO atmega328p with no problem, but I have the problem with atmega88p that I just bought the IC itself and removed atmega328p IC out and put atmega88p in, then I had this message:
Binary sketch size: 1,084 bytes (of a 32,256 byte maximum)
avrdude: stk500_getsync(): not in sync: resp=0x00
anyone knows the problem, please help. I appreciate very much.
yes, you're right. I checked my arduino UNO board with original atmega328P and I see led flashing and I remove atmega328P and replace atmega88PA and see no flashing. By the way, I watched some youtube video on how to upload the bootloader and I try, but the UNO board using atmega328P did not recognize atmega88P and I got this message:
avrdude: Expected signature for ATMEGA328P is 1E 95 0F
Double check chip, or use -F to override this check.
and I read some post online show how to work around with problem:
Workaround:
In your Arduino folder, find the subfolder: ..\hardware\tools\avr\etc
Make a backup copy of the file: avrdude.conf
Open the file avrdude.conf in a text editor
Search for: â0x1e 0x95 0x0Fâ (this is the ATmega328P signature)
Replace it with: â0x1e 0x95 0x14â (this is the ATmega328 signature)
Save the file
Restart the Arduino IDE
Continue with the rest of the steps in the instructable, and once bootloading is complete restore the backup copy you made.
I changed the signature from atmega328P to signature of atmega88PA, but I guess it did not work since I am using another atmega328P board to burn the boot loader for atmega88PA. They have different in word length when write and read, I am right? I should use atmega88PA board to burn.
i tried this in my arduino uno board to bootload atmega328p .......
it successfully bootloaded it try this method in ur board using any atmega chip........
I tried the tutorial you sent me with minimal components method because I don't have crystal and capacitors. Unfortunately, it failed and gave me the below message:
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.
Any ideas what's wrong. Thanks a lot for your help.
this check.
u must use components same as in tutorial otherwise it wont work...............................
I tried with the external crystal method and I got the different message below:
avrdude: verification error, first mismatch at byte 0x1800
0xff != 0x0c
avrdude: verification error; content mismatch
look like the tutorial uploading using arduino board with atmega328 and uploading the bootloader onto atmega168. I am using arduino uno board with atmega328P and uploading the bootloader onto atmega88P. I don't know that's the reason it did not work for me.
Do you have any suggestion what's wrong with it?
