Hello! I am using parallel programmer that I made (http://arduino.cc/en/Hacking/ParallelProgrammer) so I could upload sketches directly to Arduino without having bootloader and saving some space but when I try to upload I get: “avrdude: stk500_getsync(): not in sync: resp=0x00”. I have Arduino Duemilanove with Atmega 8. I have checked that I have marked correct board and COM properties. I would appreciate any assistance and advice.
Since you are using an external programmer(parallel in your case) then you must change the programmer type under Tools->Programmer->Parallel programmer and the use the option File->Upload using Programmer
This should do the job
Hope it helps
I have done that and I have made adjustments in the preferences file, but I still get the same message.
This error?
If yes well it's just saying you are still using the stk500 programmer no the parallel so he is right since you are using a parallel programmer.Make sure you have selected the right one.
When I change in my arduino ide to parallel programmer an try to upload I get this
avrdude: Can't find programmer id "dapa"
Valid programmers are:
c2n232i = serial port banging, reset=dtr sck=!rts mosi=!txd miso=!cts [/Applications/Arduino-1.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf:791]
dasa3 = serial port banging, reset=!dtr sck=rts mosi=txd miso=cts [/Applications/Arduino-1.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf:778]
See the diference?
avrdude try to use the right programmer "dapa".Since in my case I dont have a parallel port I get more errors but this should give you a way to follow
