Hi Guys, I have build a custom board with a ATMEGA328 processor. On the board I have connected at 74HC595 shift register with a couple of relays to control input sources which I am controlling with BC547 transistors, a rotary encoder to for input, an IR receiver to receive wireless input and a LED ring to display the status of the selected mode. I want to program the ATMEGA processor with a FTDI232 programmer. To avoid blowing up the USB of my Macbook I have installed a jumper on the board to disconnect the 5V power source from the FTDI controller. I can replace the jumper again when I disconnect the external power source. I have left the ground connected. This all used to work, but somehow I cannot program the board anymore. I am getting the following error when I try to upload a new updated code to the ATMEGA:
"avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Users/xxxxxxx/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf"
User configuration file is "/Users/xxxxxxx/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbserial-A90HG7WR
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00"
I have tried different cables, two different FTDI programmers, the processor can be programmed with a UNO board, so the processor is OK. I can read the serial port with the FTDI when I have connected it. I am out of options, I do not know how to trouble shoot this one. Any thoughts? What can I do/try to localize this issue?
