Hi Guys,
I have made a PCB with an ATMega328AU (see the schematic attacched). I have burnt the bootloader using an arduino nano. Since I have an ATMega328AU I added in the avrdude file in Arduino\hardware\tools\avr\etc the following section:
part parent "m328"
id = "m328au";
desc = "ATmega328AU";
signature = 0x1e 0x95 0x14;
ocdrev = 1;
then I connected my nano to the PCB I made, uploaded the ISP sketch and in the processor list I selected ATMega328AU and burnt the bootloader. I got the message at the end:
avrdude: verifying ...
avrdude: 1 bytes of lock verified
avrdude done. Thank you.
So I guess everything worked. now I switch the usb to the new board and try to upload the example BareMinimum. Select again the board ATMEGA328P (should be the same since the P and AU differ only by the signature), switch back to AVRISP mkll and try to upload. The IDE doesn't succeed in the uploading:
Using Port : COM19
Using Programmer : arduino
Overriding Baud Rate : 115200
I've heard about the issues with the FTDI chips so I tried a couple of them but no luck (I bought the FTDI chips on digikey so I guess this is not the issue).
Does anyone have an idea what's going on?
Thanks ![]()
uC.pdf (247 KB)
uC.pdf (247 KB)
