Hi all,
I want to use analog analog pin as digital input pin in as3 as i ran out of digital pins.
I can use it in arduino IDE by writing,
pinMode(14, INPUT);
digitalRead(14, HIGH);
but how can i use it in as3? It is not working with flash. I used the following code in as3,
import net.eriksjodin.arduino.Arduino;
import net.eriksjodin.arduino.events.ArduinoEvent;
var a:Arduino;
a = new Arduino("127.0.0.1", 5331);
a.addEventListener(Event.CONNECT , onSocketConnect);
a.addEventListener(ArduinoEvent.FIRMWARE_VERSION , onReceiveFirmwareVersion);
a.addEventListener(ArduinoEvent.DIGITAL_DATA, onReceiveDigitalData);
function onSocketConnect(e:Event):void
a.requestFirmwareVersion();
function onReceiveFirmwareVersion(e:ArduinoEvent):void
a.setPinMode(2,Arduino.INPUT);
a.setPinMode(14,Arduino.INPUT);
function onReceiveDigitalData(e:ArduinoEvent):void
trace(e.pin , e.value);
As you can see in the code I am also using digital pin 2 and it works with the digital pin 2 but its not working with digital pin 14.
I want to analog pin 0 (digital 14) to detect motion form a digital PIR sensor (high and low) without expander. I think I am missing something in flash code.
Waiting for your quick replies. I am in real urgent at this moment.
Thank you all in advance.
Cheers !!
