DistanceBySoftwareSerial.pde - URM 37 Control Library Version 2.0.0
Author: Miles Burton, miles@mnetcs.com
Copyright (c) 2009 Miles Burton All Rights Reserved
This library is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public
License along with this library; if not, write to the Free Software
Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
#include "URMSerial.h"
// The measurement we're taking
#define DISTANCE 1
#define TEMPERATURE 2
#define ERROR 3
#define NOTREADY 4
#define TIMEOUT 5
URMSerial urm;
Serial.begin(9600); // Sets the baud rate to 9600
urm.begin(6,7,9600); //RX Pin, TX Pin, Baud Rate <<<<<<<<HERE<<<<<<<<<<
Serial.println("URM37 Library by Miles Burton - Distance. Version 2.0"); // Shameless plug
Serial.println("Measurement: ");
Serial.println(getMeasurement()); // Output measurement
int value; // This value will be populated
int getMeasurement()
// Request a distance reading from the URM37
switch(urm.requestMeasurementOrTimeout(DISTANCE, value)) // Find out the type of request
case DISTANCE: // Double check the reading we recieve is of DISTANCE type
// Serial.println(value); // Fetch the distance in centimeters from the URM37
return value;
case TEMPERATURE:
return value;
case ERROR:
Serial.println("Error");
case NOTREADY:
Serial.println("Not Ready");
case TIMEOUT:
Serial.println("Timeout");
return -1;
Help!!!!!!!!!!
Is the code above a RS232 mode or TTL mode when I connect it on my Arduino Uno?
Referhttp://letsmakerobots.com/files/URM3.2_Mannual_Rev2.pdffor more details on RS232 and TTL mode on this sensor!!
Is the RX and TX (find for <<<<<<<<<<HERE<<<<<<<<<<<< up there) above is referring pin RX and TX respectively on the Arduino? Does the TX and RX pin of the URM 37 connected to the RX and TX pin on the Arduino respectively?
I do not want to spoil my sensor.
gf
