Usare una password per eseguire un pezzo di codice.
Ciao a tutti ragazzi, come prima cosa mi scuso per la mia ignoranza. Volevo porvi un quesito, per lavoro ho bisogno di creare un circuito che mostri delle parole già in memoria su un matrix a gestire il fatto del codice.
Sto usando un keypad 3x4.
GRAZIE A TUTTI PER L'AIUTO!
L'arduino deve fare un bip ogni volta che si preme un tasto, una volta inserito un codice di tre cifre (ad esempio 000) deve eseguire questo codice:
#define COL_PIXEL     64
#define ROW_PIXEL     16
int latchPin=8; //LT
int clockPin=12;//SK
int dataPin=11; //R1
int en_74138 = 2;
int la_74138 = 3;
int lb_74138 = 4;
int lc_74138 = 5;
int ld_74138 = 6;
unsigned int ROW_xPixel;
unsigned int ROW_num;
unsigned char Col_num_1;
unsigned char Col_num_2;
unsigned char Col_num_3;
unsigned char Col_num_4;
unsigned char Col_num_5;
unsigned char Col_num_6;
unsigned char Col_num_7;
unsigned char Col_num_8;
//Data code: Horizontal modulus ,Bytes reverse order
unsigned char  Bmp1[]=
;  Width X height (pixels): 64X16 example code for matrix
; word written: I love you
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0xc0, 0xff, 0x0, 0x3, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0xc, 0xc0, 0x0, 0x0, 0x0,
0x0, 0x0, 0xc, 0x0, 0x3, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0xc, 0xc0, 0x0, 0x0, 0x0, 0x0, 0x0, 0xc, 0x0, 0x3, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x30, 0x30, 0x0, 0x0, 0x0, 0x0, 0x0, 0xc, 0x0, 0x3, 0xc0, 0x3, 0x3, 0x30, 0xf0, 0x0, 0xc0, 0xc,
0xf0, 0xc0, 0x0, 0x3, 0x0, 0xc, 0x0, 0x3, 0x30, 0xc, 0x3, 0x30, 0xc, 0x3, 0x0, 0x3, 0xc, 0xc3, 0x0, 0x3, 0x0, 0xc,
0x0, 0x3, 0xc, 0x30, 0x3, 0x30, 0x3, 0xc, 0x0, 0x3, 0x3, 0xcc, 0x0, 0x3, 0x0, 0xc, 0x0, 0x3, 0xc, 0x30, 0x3, 0x30,
0x3, 0xc, 0x0, 0x3, 0x3, 0xcc, 0x0, 0x3, 0x0, 0xc, 0x0, 0x3, 0xc, 0x30, 0x3, 0x30, 0xf, 0xc, 0x0, 0x3, 0x3, 0xcc,
0x0, 0x3, 0x0, 0xc, 0x0, 0x3, 0xc, 0x30, 0x3, 0x30, 0xf3, 0x3, 0x0, 0x3, 0x3, 0xcc, 0x0, 0x3, 0x0, 0xc, 0x0, 0x3,
0xc, 0x30, 0xc, 0xc, 0x3, 0x0, 0x0, 0x3, 0x3, 0xcc, 0x0, 0x3, 0x0, 0xc, 0x0, 0xc3, 0x30, 0xc, 0x30, 0x3, 0x3, 0xc,
0x0, 0x3, 0xc, 0xc3, 0x0, 0x3, 0xc0, 0xff, 0x0, 0xff, 0xc0, 0x3, 0xc0, 0x0, 0xfc, 0x3, 0x0, 0x3, 0xf0, 0x0, 0xff,
void shiftOut(unsigned char dataOut)
    for(int i=0;i<=7;i++)
      PORTB &=~(1<<(clockPin-8));//equate digitalWrite(clockPin,LOW);
     if(dataOut & (0x01<<i))  PORTB |=1<<(dataPin-8); //equate digitalWrite(dataPin,HIGH);
     else  PORTB &=~(1<<(dataPin-8));//equate digitalWrite(dataPin,LOW);
     PORTB |=1<<(clockPin-8);//equate digitalWrite(clockPin,HIGH);
//Combine 2 bits/pixel to 1 bits/pixel
unsigned char Combine_2BitsTo1Bit(unsigned char num,unsigned char *BMP)
  unsigned char Col_num_tem_1;
  unsigned char Col_num_tem_2;
  unsigned int Col_num_tem = 0;
  unsigned char i=0;
  unsigned char Col_num_1bit = 0x00;
  Col_num_tem_1 = *(BMP+num);
  Col_num_tem_2 = *(BMP+num+1);
  Col_num_tem = Col_num_tem_1;
  Col_num_tem |= (Col_num_tem_2 << 8);
 for(i=0;i<8;i++)
    if(Col_num_tem&(0x0003<<i*2)) Col_num_1bit |= (0x01<<i);
  return ~Col_num_1bit;
//display one picture
void display_martix(unsigned char *BMP)
  //Display count
  unsigned int dis_cnt=256;
  unsigned int i;
   for(i=0;i<dis_cnt*16;i++)
     digitalWrite(en_74138, HIGH);//Turn off display
     //Col scanning
    shiftOut(Col_num_1);
    shiftOut(Col_num_2);
    shiftOut(Col_num_3);
    shiftOut(Col_num_4);
    shiftOut(Col_num_5);
    shiftOut(Col_num_6);
    shiftOut(Col_num_7);
    shiftOut(Col_num_8);
    digitalWrite(latchPin, LOW);
    digitalWrite(latchPin, HIGH);
    //Row scanning
    // AVR Port Operation
    PORTD = ((ROW_xPixel << 3 ) & 0X78) | (PORTD & 0X87);//Write PIN 3 4 5 6 la_74138 lb_74138 lc_74138 ld_74138
    digitalWrite(en_74138, LOW);//Turn on display
    if(ROW_xPixel==15) ROW_xPixel=0; else ROW_xPixel++;
   // Single color,1 bits/pixel
   Col_num_1=~BMP[(COL_PIXEL/8)*ROW_xPixel];
   Col_num_2=~BMP[(COL_PIXEL/8)*ROW_xPixel+1];
   Col_num_3=~BMP[(COL_PIXEL/8)*ROW_xPixel+2];
   Col_num_4=~BMP[(COL_PIXEL/8)*ROW_xPixel+3];
   Col_num_5=~BMP[(COL_PIXEL/8)*ROW_xPixel+4];
   Col_num_6=~BMP[(COL_PIXEL/8)*ROW_xPixel+5];
   Col_num_7=~BMP[(COL_PIXEL/8)*ROW_xPixel+6];
   Col_num_8=~BMP[(COL_PIXEL/8)*ROW_xPixel+7];
   //Single color,2 bits/pixel
   Col_num_1 = Combine_2BitsTo1Bit((COL_PIXEL/8)*ROW_xPixel*2,BMP);
   Col_num_2 = Combine_2BitsTo1Bit((COL_PIXEL/8)*ROW_xPixel*2+2,BMP);
   Col_num_3 = Combine_2BitsTo1Bit((COL_PIXEL/8)*ROW_xPixel*2+4,BMP);
   Col_num_4 = Combine_2BitsTo1Bit((COL_PIXEL/8)*ROW_xPixel*2+6,BMP);
   Col_num_5 = Combine_2BitsTo1Bit((COL_PIXEL/8)*ROW_xPixel*2+8,BMP);
   Col_num_6 = Combine_2BitsTo1Bit((COL_PIXEL/8)*ROW_xPixel*2+10,BMP);
   Col_num_7 = Combine_2BitsTo1Bit((COL_PIXEL/8)*ROW_xPixel*2+12,BMP);
   Col_num_8 = Combine_2BitsTo1Bit((COL_PIXEL/8)*ROW_xPixel*2+14,BMP);
  // delayMicroseconds(1000);
  pinMode(latchPin,OUTPUT);
  pinMode(clockPin,OUTPUT);
  pinMode(dataPin,OUTPUT);
  pinMode(en_74138,OUTPUT);
  pinMode(la_74138,OUTPUT);
  pinMode(lb_74138,OUTPUT);
  pinMode(lc_74138,OUTPUT);
  pinMode(ld_74138,OUTPUT);
  // AVR Port Settings
  DDRD |= 0x78; //Set PIN 3 4 5 6 output
 display_martix(Bmp1);
Buonasera,
essendo il tuo primo post nella sezione Italiana del forum, nel rispetto del regolamento di detta sezione (… punto 13, primo capoverso), ti chiedo cortesemente di presentarti IN QUESTO THREAD (spiegando bene quali conoscenze hai di elettronica e di programmazione ... possibilmente evitando di scrivere solo una riga di saluto) e di leggere con molta attenzione tutto il su citato REGOLAMENTO ... Grazie. :slight_smile:
Guglielmo
P.S.: Ti ricordo che, purtroppo, fino a quando non sarà fatta la presentazione nell’apposito thread, nessuno ti potrà rispondere, quindi ti consiglio di farla al più presto. :wink:
Fatto :slight_smile:
Se provi a cercare qui sul forum (puoi usare la piccola lente di ingrandimento che vedi in alto a destra), vedrai che ci sono varie discussioni relative allo stesso argomento.
Nel tuo caso basterà creare una funzione che verifica la corretta introduzione della password e, al corretto inserimento, potrà tornare indietro permettendo l'esecuzione del resto del programma.
Guglielmo
Ho aperto un thread proprio per questo, ho cercato di modificare vari codici di gente che aveva creato un codice per comandare i servo come serrature, ma appena facevo una modifica compraivano moltissimi errori.
Inserisco sotto il codice che ho scritto senza errori per adesso, per quanto riguarda "conservare" la password e fare in modo che esegua il codice, non ho ancora trovato un comando per farlo.
#include <Keypad.h>
int position = 0;
#define buzzer 12;
const byte rows = 4;
const byte cols = 3;
char keyMap [rows][cols] = {
  {'1', '2', '3'},
  {'4', '5', '6'},
  {'7', '8', '9'},
  {'*', '0', '#'}
byte rowPins[rows] = { 5, 6, 7, 8};
byte colPins[cols] = {4, 3, 2 };
Keypad myKeypad = Keypad( makeKeymap(keyMap), rowPins, colPins, rows, cols);
 char key = keypad.getKey();
    tone(buzzer, 1500, 100)
