USB Button Box with Toggles and Momentary
Good day all
Just to let you know im new on here and im not after trolling just some guidance and if i can give back to the community.
I am trying to build a button box which both has toggle switches and momentary. I have sucessfully got momentary working fine then i tried to add part of a script for the toggles. Now all the buttons toggle and none are momentary. What i want to be able to do can i specify which buttons will be toggle and which will be momentary ?
If someone can help change the script please do and post would be appreciated
Thank you for your help in advance. :slight_smile:
#include <Joystick.h>
#include <Key.h>
#include <Keypad.h>
#include <Bounce2.h>
#include <elapsedMillis.h>
#define ENABLE_PULLUPS
#define NUMROTARIES 4
#define NUMBUTTONS 24
#define NUMROWS 5
#define NUMCOLS 5
//Assigns Rows and columns with button numbering
byte buttons[NUMROWS][NUMCOLS] = {
{0, 1, 2, 3, 4},
{5, 6, 7, 8, 9},
{10, 11, 12, 13, 14},
{15, 16, 17, 18, 19},
{20, 21, 22, 23},
struct rotariesdef {
byte pin1;
byte pin2;
int ccwchar;
int cwchar;
volatile unsigned char state;
rotariesdef rotaries[NUMROTARIES] {
{0, 1, 24, 25, 0},
{2, 3, 26, 27, 0},
{4, 5, 28, 29, 0},
{6, 7, 30, 31, 0},
#define DIR_CCW 0x10
#define DIR_CW 0x20
#define R_START 0x0
#ifdef HALF_STEP
#define R_CCW_BEGIN 0x1
#define R_CW_BEGIN 0x2
#define R_START_M 0x3
#define R_CW_BEGIN_M 0x4
#define R_CCW_BEGIN_M 0x5
const unsigned char ttable[6][4] = {
// R_START (00)
{R_START_M, R_CW_BEGIN, R_CCW_BEGIN, R_START},
// R_CCW_BEGIN
{R_START_M | DIR_CCW, R_START, R_CCW_BEGIN, R_START},
// R_CW_BEGIN
{R_START_M | DIR_CW, R_CW_BEGIN, R_START, R_START},
// R_START_M (11)
{R_START_M, R_CCW_BEGIN_M, R_CW_BEGIN_M, R_START},
// R_CW_BEGIN_M
{R_START_M, R_START_M, R_CW_BEGIN_M, R_START | DIR_CW},
// R_CCW_BEGIN_M
{R_START_M, R_CCW_BEGIN_M, R_START_M, R_START | DIR_CCW},
#else
#define R_CW_FINAL 0x1
#define R_CW_NEXT 0x3
#define R_CCW_BEGIN 0x4
#define R_CCW_FINAL 0x5
#define R_CCW_NEXT 0x6
const unsigned char ttable[7][4] = {
// R_START
{R_START, R_CW_BEGIN, R_CCW_BEGIN, R_START},
// R_CW_FINAL
{R_CW_NEXT, R_START, R_CW_FINAL, R_START | DIR_CW},
// R_CW_BEGIN
{R_CW_NEXT, R_CW_BEGIN, R_START, R_START},
// R_CW_NEXT
{R_CW_NEXT, R_CW_BEGIN, R_CW_FINAL, R_START},
// R_CCW_BEGIN
{R_CCW_NEXT, R_START, R_CCW_BEGIN, R_START},
// R_CCW_FINAL
{R_CCW_NEXT, R_CCW_FINAL, R_START, R_START | DIR_CCW},
// R_CCW_NEXT
{R_CCW_NEXT, R_CCW_FINAL, R_CCW_BEGIN, R_START},
#endif
byte rowPins[NUMROWS] = {21, 20, 19, 18, 15};
byte colPins[NUMCOLS] = {14, 16, 10, 9, 8,};
Keypad buttbx = Keypad( makeKeymap(buttons), rowPins, colPins, NUMROWS, NUMCOLS);
Joystick_ Joystick(JOYSTICK_DEFAULT_REPORT_ID,
JOYSTICK_TYPE_JOYSTICK, 32, 0,
false, false, false, false, false, false,
false, false, false, false, false);
Joystick.begin();
rotary_init();
CheckAllEncoders();
CheckAllButtons();
void CheckAllButtons(void) {
if (buttbx.getKeys())
for (int i = 0; i < LIST_MAX; i++)
if ( buttbx.key[i].stateChanged )
if(i >= 1 && i <= 22) {
// do toggle things
else {
// do non-toggle things
switch (buttbx.key[i].kstate) {
case PRESSED:
case HOLD:
Joystick.setButton(buttbx.key[i].kchar, 1);
delay(0);
case RELEASED:
case IDLE:
Joystick.setButton(buttbx.key[i].kchar, 0);
delay(0);
case PRESSED:
delay(100);
case RELEASED:
delay(100);
void rotary_init() {
for (int i = 0; i < NUMROTARIES; i++) {
pinMode(rotaries[i].pin1, INPUT);
pinMode(rotaries[i].pin2, INPUT);
#ifdef ENABLE_PULLUPS
digitalWrite(rotaries[i].pin1, HIGH);
digitalWrite(rotaries[i].pin2, HIGH);
#endif
unsigned char rotary_process(int _i) {
unsigned char pinstate = (digitalRead(rotaries[_i].pin2) << 1) | digitalRead(rotaries[_i].pin1);
rotaries[_i].state = ttable[rotaries[_i].state & 0xf][pinstate];
return (rotaries[_i].state & 0x30);
void CheckAllEncoders(void) {
unsigned char result = rotary_process(i);
if (result == DIR_CCW) {
Joystick.setButton(rotaries[i].ccwchar, 1); delay(50); Joystick.setButton(rotaries[i].ccwchar, 0);
if (result == DIR_CW) {
Joystick.setButton(rotaries[i].cwchar, 1); delay(50); Joystick.setButton(rotaries[i].cwchar, 0);
Please attach code, not massive text. Use the code tag symbol, </>, told in the topic "How to use this Forum".
Rocker switches can easily be handle as push buttons. The only difference is that one "button" negates the other.
#include <Key.h>
#include <Keypad.h>
#define NUMROWS 5
#define NUMCOLS 5
  {0, 1, 2, 3, 4},
  {5, 6, 7, 8, 9},
  {20, 21, 22, 23},
  byte pin1;
  byte pin2;
  int ccwchar;
  int cwchar;
  {0, 1, 24, 25, 0},
  {2, 3, 26, 27, 0},
  {4, 5, 28, 29, 0},
  {6, 7, 30, 31, 0},
#define DIR_CW 0x20
#define R_START 0x0
#ifdef HALF_STEP
  // R_START (00)
  // R_CCW_BEGIN
  // R_CW_BEGIN
  // R_START_M (11)
  // R_CW_BEGIN_M
  // R_CCW_BEGIN_M
#else
  // R_START
  // R_CW_FINAL
  // R_CW_BEGIN
  // R_CW_NEXT
  // R_CCW_BEGIN
  // R_CCW_FINAL
  // R_CCW_NEXT
#endif
  Joystick.begin();
  rotary_init();
  CheckAllEncoders();
  CheckAllButtons();
   // do toggle things
else {
          case PRESSED:
          case HOLD:
            delay(0);
          case RELEASED:
          case IDLE:
            delay(0);
          case PRESSED:
            delay(100);
          case RELEASED:
            delay(100);
#endif
Up there now :slight_smile:
Please explain exactly what you want to do.
What Arduino ?
Show us a good schematic of your circuit.
Show us a good image of your ‘actual’ wiring.
Give links to components.
Sorry this is for Pro Micro board
Im trying to make code to allow for momentary presses and toggles, i can do either or but cant work out how to do both
If your toggles are ON/OFF then they will interfere with others switches.
Google keypad ghosting diode.
ok so im thinking then to commit a row purely for momentary and row for toggle this shoud over this correct ? rather than having mixture on each line of ,matrix
No, for multiple switch press capability, you need one diode per switch.
Please see below. I have got what i believe the correct code to have both momentary and toggle switches however with the code below it will only allow me to do toggles. im after some help and it would be aprpeciated.
   // do toggle things
else {
          case PRESSED:
            delay(100);
          case RELEASED:
            delay(100);
                    case PRESSED:
                    case HOLD:
                    case RELEASED:
                    case IDLE:
