Hello, I received a new usb host shield today and have downloaded and installed the library. I have been looking through the sample codes online and don't see anything for what I'm wanting to do.
Basically I want to open a file and write a dataString to it. That's it, I don't need to read from it (except when removed and plugged into a pc.
Does anyone have sample data for this? It seems its not going to be as simple as writing to an sd card, is this true?
My arduino is a data logger which currently logs to SD and when prompted by a switch it sends the recorded file to the pc via Bluetooth. This all works but I would like to also have the file recorded to a usb flashdrive (memory stick) .
My data is currently sent as a data string to a file on SD as a csv file.
I'm hoping through a similar code I can send the info to the flashdrive.
