USB Host Shield 2.0 + Arduino freezing after some time
Hey there! I'm new to the arduino space so bear with me. I have an arduino leonardo with a USB host shield 2.0 stacked on top of it. I've got it soldered to supply 5v power to the usb device. The arduino is connected to a PC usb port using a USB-A to micro USB cable.
I am running examples/USB Host Shield 2.0 Library/HID/USBHID_desc.ino (code at bottom of post) to print out the HID descriptor and any inputs being pressed. The mouse I am using is wireless so I have the wireless dongle connected via a USB-A to USB-C cable.
At first the program prints to the Serial Monitor (115200 baud) just fine, and prints mouse input for a while but eventually it freezes. That is all output stops even when moving the mouse / pressing buttons on the mouse. The lights on the mouse / receiver stay on once input stops. This happens when using the wireless dongle AND when plugging the mouse directly in (wired mode).
I have tried 2 other mice, 1 logitech (wireless) and 1 razer (wired) and have not had the same problem happen. The mouse I am using is a WLMouse Beast X mini. I suspect maybe this is something with the wireless receiver firmware or mouse firmware but I'm at a loss as to what or how to diagnose further.
I have also ran code that reads the descriptor and passes in values to mouse.move() which works, until the arduino/shield freezes and the cursor freezes.
I've tried redoing the soldering, running diagnostics (board_qc.ino passes), messing with polling, and running on a different PC none of which have changed the outcome.
Any help would be greatly appreciated!!
Other stats about the mouse and code used:
I've tried both 500hz and 1000hz polling rate
USB Descriptor for the dongle (pulled via usbview.exe):
[Port6]  :  USB Composite Device
Is Port User Connectable:         yes
Is Port Debug Capable:            no
Companion Port Number:            1
Companion Hub Symbolic Link Name: USB#ROOT_HUB30#9&265260e5&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
Protocols Supported:
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
Device Power State:               PowerDeviceD0
       ---===>Device Information<===---
English product name: "WLmouse mini receiver"
ConnectionStatus:
Current Config Value:              0x01  -> Device Bus Speed: High (is not SuperSpeed or higher capable)
Device Address:                    0x18
Open Pipes:                           3
          ===>Device Descriptor<===
bLength:                           0x12
bDescriptorType:                   0x01
bcdUSB:                          0x0200
bDeviceClass:                      0x00  -> This is an Interface Class Defined Device
bDeviceSubClass:                   0x00
bDeviceProtocol:                   0x00
bMaxPacketSize0:                   0x40 = (64) Bytes
idVendor:                        0x36A7 = Vendor ID not listed with USB.org
idProduct:                       0xA885
bcdDevice:                       0x0100
iManufacturer:                     0x01
     English (United States)  "WL"
iProduct:                          0x02
     English (United States)  "WLmouse mini receiver"
iSerialNumber:                     0x03
     English (United States)  "0B93ABCD73BABC5A"
bNumConfigurations:                0x01
          ---===>Open Pipes<===---
          ===>Endpoint Descriptor<===
bLength:                           0x07
bDescriptorType:                   0x05
bEndpointAddress:                  0x81  -> Direction: IN - EndpointID: 1
bmAttributes:                      0x03  -> Interrupt Transfer Type
wMaxPacketSize:                  0x0008 = 1 transactions per microframe, 0x08 max bytes
bInterval:                         0x01
bLength:                           0x07
bEndpointAddress:                  0x82  -> Direction: IN - EndpointID: 2
wMaxPacketSize:                  0x0040 = 1 transactions per microframe, 0x40 max bytes
bInterval:                         0x01
bLength:                           0x07
bEndpointAddress:                  0x83  -> Direction: IN - EndpointID: 3
bInterval:                         0x01
       ---===>Full Configuration Descriptor<===---
          ===>Configuration Descriptor<===
bLength:                           0x09
bDescriptorType:                   0x02
wTotalLength:                    0x0054  -> Validated
bNumInterfaces:                    0x03
bConfigurationValue:               0x01
iConfiguration:                    0x00
bmAttributes:                      0xA0  -> Bus Powered
  -> Remote Wakeup
MaxPower:                          0xFA = 500 mA
          ===>Interface Descriptor<===
bLength:                           0x09
bDescriptorType:                   0x04
bInterfaceNumber:                  0x00
bAlternateSetting:                 0x00
bNumEndpoints:                     0x01
bInterfaceClass:                   0x03  -> HID Interface Class
bInterfaceSubClass:                0x01
bInterfaceProtocol:                0x02
iInterface:                        0x00
          ===>HID Descriptor<===
bLength:                           0x09
bDescriptorType:                   0x21
bcdHID:                          0x0111
bCountryCode:                      0x00
bNumDescriptors:                   0x01
bDescriptorType:                   0x22 (Report Descriptor)
wDescriptorLength:               0x005F
bLength:                           0x07
bInterval:                         0x01
bLength:                           0x09
bInterfaceNumber:                  0x01
bNumEndpoints:                     0x01
bInterfaceProtocol:                0x01
iInterface:                        0x00
bLength:                           0x09
bcdHID:                          0x0111
bCountryCode:                      0x00
wDescriptorLength:               0x00A4
bLength:                           0x07
bInterval:                         0x01
bLength:                           0x09
bInterfaceNumber:                  0x02
bNumEndpoints:                     0x01
bInterfaceSubClass:                0x00
bInterfaceProtocol:                0x00
iInterface:                        0x00
bLength:                           0x09
bcdHID:                          0x0111
bCountryCode:                      0x00
wDescriptorLength:               0x0014
bLength:                           0x07
bInterval:                         0x01
USB descriptor for the mouse (pulled via usbview.exe):
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
English product name: "WLmouse mini"
ConnectionStatus:
Current Config Value:              0x01  -> Device Bus Speed: Full (is not SuperSpeed or higher capable)
Device Address:                    0x19
Open Pipes:                           3
bLength:                           0x12
bcdUSB:                          0x0200
idProduct:                       0xA886
bcdDevice:                       0x0260
iManufacturer:                     0x01
iProduct:                          0x02
     English (United States)  "WLmouse mini"
iSerialNumber:                     0x03
     English (United States)  "3A16C933"
bLength:                           0x07
wMaxPacketSize:                  0x0040 = 0x40 bytes
bInterval:                         0x01
bLength:                           0x07
bInterval:                         0x01
bLength:                           0x07
bInterval:                         0x01
bLength:                           0x09
bmAttributes:                      0xE0  -> Self Powered
  -> Remote Wakeup
MaxPower:                          0x32 = 100 mA
bLength:                           0x09
bNumEndpoints:                     0x01
iInterface:                        0x00
bLength:                           0x09
bcdHID:                          0x0111
bCountryCode:                      0x00
wDescriptorLength:               0x005B
bLength:                           0x07
bInterval:                         0x01
bLength:                           0x09
bNumEndpoints:                     0x01
iInterface:                        0x00
bLength:                           0x09
bcdHID:                          0x0111
bCountryCode:                      0x00
wDescriptorLength:               0x00A3
bLength:                           0x07
bInterval:                         0x01
bLength:                           0x09
bNumEndpoints:                     0x01
iInterface:                        0x00
bLength:                           0x09
bcdHID:                          0x0111
bCountryCode:                      0x00
bLength:                           0x07
bInterval:                         0x01
Taken from USB_Host_Shield_2.0/examples/HID/USBHID_desc/USBHID_desc.ino at master · felis/USB_Host_Shield_2.0 · GitHub
#include <usbhid.h>
#include <hiduniversal.h>
#include <hidescriptorparser.h>
#include <usbhub.h>
#include "pgmstrings.h"
// Satisfy the IDE, which needs to see the include statment in the ino too.
#ifdef dobogusinclude
#include <spi4teensy3.h>
#endif
#include <SPI.h>
class HIDUniversal2 : public HIDUniversal
public:
    HIDUniversal2(USB *usb) : HIDUniversal(usb) {};
protected:
    uint8_t OnInitSuccessful();
uint8_t HIDUniversal2::OnInitSuccessful()
    uint8_t    rcode;
    HexDumper<USBReadParser, uint16_t, uint16_t>    Hex;
    ReportDescParser                                Rpt;
    if ((rcode = GetReportDescr(0, &Hex)))
        goto FailGetReportDescr1;
    if ((rcode = GetReportDescr(0, &Rpt)))
	goto FailGetReportDescr2;
    return 0;
FailGetReportDescr1:
    USBTRACE("GetReportDescr1:");
    goto Fail;
FailGetReportDescr2:
    USBTRACE("GetReportDescr2:");
    goto Fail;
Fail:
    Serial.println(rcode, HEX);
    Release();
    return rcode;
USB Usb;
//USBHub Hub(&Usb);
HIDUniversal2 Hid(&Usb);
UniversalReportParser Uni;
  Serial.begin( 115200 );
#if !defined(__MIPSEL__)
  while (!Serial); // Wait for serial port to connect - used on Leonardo, Teensy and other boards with built-in USB CDC serial connection
#endif
  Serial.println("Start");
  if (Usb.Init() == -1)
      Serial.println("OSC did not start.");
  delay( 200 );
  if (!Hid.SetReportParser(0, &Uni))
      ErrorMessage<uint8_t>(PSTR("SetReportParser"), 1  );
    Usb.Task();
Everybody is in the beginning. No shame in that but please read and use this link: How to get the best out of this forum - Projects / General Guidance - Arduino Forum
Thank you for the link! I've added the code I am using that results in the freeze and more details about the freeze. Is there any other information I should add? It's been kind of hard to debug exactly whats going on because the serial output just freezes with this specific mouse.
If that's true, don't use that mouse :smirk:
I suspect your mouse isn't strictly playing by the book. While a device works fine in Windows, doesn't mean it's without issues, it's just that the USB implementation in Windows are forgiving. Then a less "experienced" host device is connected and chokes.
Not the solution you want, but it's easier to just move on instead of a probable Don Quijote.
Haha this is the solution im heading towards. Its just gnawing at me that this mouse is special with its implementation for some reason
For a less caring manufacturer, most important thing is that the device works with Windows since that's where they hit the biggest market. The quicker developing and QC goes, the quicker they can get profit.
Reading the code using GoTo I ask you for a flowchart. Execution jumping around easily leads to a spagettit behaviour that I'll not try analyze.
