USB Host Shield 2.0 - How to enable DTR and RTS ?
I try to receive data from an USB FTDI device (which push data every 10 secondes) then display the data in my Arduino Monitor.
The problem is (I think) I have to enable DTR and RTS from my USB Host Shield 2.0, but I don't know how to do it.
USB Configuration I need:
Baudrate: 115200
Flow Control: Only XON
DTR and RTS on
Capture local echo
Can somebody help me please ?
I'm using an Arduino UNO + USB Host Shield 2.0.
My code:
#include <SD.h>
#include <adk.h>
#include <cdcftdi.h>
//#include <usbhub.h>
#include "pgmstrings.h"
class FTDIAsync : public FTDIAsyncOper
public:
  virtual uint8_t OnInit(FTDI *pftdi);
uint8_t FTDIAsync::OnInit(FTDI *pftdi)
  uint8_t rcode = 0;
  rcode = pftdi->SetBaudRate(115200);
  if (rcode)
    ErrorMessage<uint8_t>(PSTR("SetBaudRate"), rcode);
    return rcode;
  rcode = pftdi->SetFlowControl(FTDI_SIO_DISABLE_FLOW_CTRL, FTDI_SIO_XON_XOFF_HS);
  if (rcode)
    ErrorMessage<uint8_t>(PSTR("SetFlowControl"), rcode);
  return rcode;
int led = 13;
USB Usb;
//USBHub Hub1(&Usb);
FTDIAsync        FtdiAsync;
FTDI             Ftdi(&Usb, &FtdiAsync);
uint32_t next_time;
// the setup routine runs once when you press reset:
  // initialize the digital pin as an output.
  pinMode(led, OUTPUT);
  //For usb
  if (Usb.Init() == -1) {
    Serial.println("KO: OSC did not start.");
  else {
    Serial.println("OK: OSC start.");
  delay( 2000 );
  next_time = millis() + 5000;
  //End for usb
// the loop routine runs over and over again forever:
  Usb.Task();
  if( Usb.getUsbTaskState() == USB_STATE_RUNNING )
    digitalWrite(led, HIGH);
    uint8_t  rcode;
    uint8_t  buf[64];
    for (uint8_t i=0; i<64; i++)
      buf[i] = 0;
    uint16_t rcvd = 64;
    rcode = Ftdi.RcvData(&rcvd, buf);
    Serial.println(rcvd);
    if (rcode && rcode != hrNAK)
      ErrorMessage<uint8_t>(PSTR("Ret"), rcode);
    // The device reserves the first two bytes of data
    //   to contain the current values of the modem and line status registers.
    if (rcvd > 2)
      Serial.print((char*)(buf+2));
    delay(10);
    digitalWrite(led, LOW);
Thank you in advance.
