Using USB Host Shield 2.0 with CH340 FTDI, USB Serial
Trying to connect using the USB Host Shield 2.0 to a USB device (Geiger Counter) that is using a built in CH340 FTDI/UART chip (Not a P2109/1) Which basically uses the Serial FTDI to give access to text commands to get data from device.
The Board is a ESP32 without a USB Host controller on board.
Does anyone know of any working examples using library with CH340 FTDI/UART?
Found these this reference to one but getting compile errors (think it may be because the USB Host Shield 2.0 Library is later version)
(.zip contains code) By
@ardcp
@kaza007
[Arduino Usb Host Shield 2.0, ch340 driver problem.]
[USB Host Shield (max3421e) Receive limitations]
Ahh ignore that, got it going was just how I expanded the files.
Created a new folder in USB Host Sheild 2.0 'examples' directory, copied files there then moved *.cpp & *.h to the main root folder of the library!
Working well sending cmd's & receiving data back from Geiger Counter! Thankyou!
Just wonder if you have this code up on GitHub? As could not find!
Be really good to try & get a Pull Request up for addition to Felis/USB_Host_Shield_2.0 Repo as really useful bit of code I'm sure many will get value from when hit same issue!
[GitHub - felis/USB_Host_Shield_2.0: Revision 2.0 of USB Host Library for Arduino.]
