Noob here, so go easy on me ![]()
I'm trying to build a USB MIDI foot controller that will simply send MIDI CC messages when buttons are pressed. I'm using a keyestudio Leonardo board for it's native USB support, so I can do MIDI over USB.
The issue I'm finding is that rather than sending each CC message once, when one of the buttons is pressed, it's just endlessly sending all of the messages all the time (confirmed with both the serial monitor and the MIDI message monitor in my DAW).
Any insight would be gratefully received.
#include "MIDIUSB.h"
const int btn1 = 2;
const int btn2 = 3;
const int btn3 = 4;
const int btn4 = 5;
int btn1State = HIGH;
int btn2State = HIGH;
int btn3State = HIGH;
int btn4State = HIGH;
pinMode(btn1, INPUT_PULLUP);
pinMode(btn2, INPUT_PULLUP);
pinMode(btn3, INPUT_PULLUP);
pinMode(btn4, INPUT_PULLUP);
// First parameter is the event type (0x0B = control change).
// Second parameter is the event type, combined with the channel.
// Third parameter is the control number number (0-119).
// Fourth parameter is the control value (0-127).
void controlChange(byte channel, byte control, byte value) {
midiEventPacket_t event = {0x0B, 0xB0 | channel, control, value};
MidiUSB.sendMIDI(event);
btn1State = digitalRead(btn1);
btn2State = digitalRead(btn2);
btn3State = digitalRead(btn3);
btn4State = digitalRead(btn4);
if (btn1State == LOW) {
Serial.println("Sending CC 60 127");
controlChange(0, 60, 127);
if (btn2State == LOW) {
Serial.println("Sending CC 61 127");
controlChange(0, 61, 127);
if (btn3State == LOW) {
Serial.println("Sending CC 62 127");
controlChange(0, 62, 127);
if (btn4State == LOW) {
Serial.println("Sending CC 63 127");
controlChange(0, 63, 127);
