I managed to get my Arduino UNO R3 working just fine in Ubuntu 15.10 and Arduino IDE 1.6.1.
But suddenly, today, it stopped working. When I plug the board in I get the following in dmesg:
usb 6-1: new full-speed USB device number 32 using uhci_hcd
usb 6-1: New USB device found, idVendor=2341, idProduct=0043
usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=220
usb 6-1: Manufacturer: Arduino (www.arduino.cc)
usb 6-1: SerialNumber: 7413736373735141A082
cdc_acm 6-1:1.0: ttyACM0: USB ACM device
usb 6-1: USB disconnect, device number 32
usb 6-1: new full-speed USB device number 33 using uhci_hcd
usb 6-1: New USB device found, idVendor=03eb, idProduct=2fef
usb 6-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
usb 6-1: USB disconnect, device number 33
usb 6-1: new full-speed USB device number 34 using uhci_hcd
So, for some reason the USB device is disconnected twice and then stays in a limbo state. I can't see any /dev/ttyACM* and the IDE can't select a port.
BUT I am able to briefly, for a second or so, see the port enabled in the IDE.
Did any of you experience this before? How can I fix it? The instructions in the main website didn't help :(.
I have an extra bit of information that might help to figure out what's going on.
When I go back to Windows, I can program the Arduino again and everything is as expected. Then, when I return to Ubuntu, I can see the port and I can program the board, but only once! After that, the problem happens and I have to return to Windows again. Does this make any sense? I guess the way the Arduino is programmed in Linux messes up with the board somehow.
Same problem here, i already uninstall brltty. And problem still going on.
FT232RL work sometimes and disconnect.
[10594.042280] usb 6-2: Detected FT232RL
[10594.042283] usb 6-2: Number of endpoints 2
[10594.042285] usb 6-2: Endpoint 1 MaxPacketSize 64
[10594.042288] usb 6-2: Endpoint 2 MaxPacketSize 64
[10594.042290] usb 6-2: Setting MaxPacketSize 64
[10594.044358] usb 6-2: FTDI USB Serial Device converter now attached to ttyUSB0
[10605.640117] usb 6-2: USB disconnect, device number 42
[10605.640279] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
[10605.640294] ftdi_sio 6-2:1.0: device disconnected
[10614.240147] usb 6-2: new full-speed USB device number 43 using uhci_hcd
You won't believe what was causing this all the time...
The Arduino was mounted on a home made robot chassis. And it was fixed to the chassis through the mounting holes. Specifically, the mounting hole next to the ICSP programming pins had a metallic nut and bolt underneath.
The nut was short-circuiting the RESET and GND pins effectively putting the ATmega16U2 in DFU mode!!! As soon as I added a bit of insulation plastic underneath, the problem went away.
Gabriel, might this be the problem that you're also experiencing? If not, maybe you need to re-program your ATmega16U2. Check-out these links:
