Hello,
if got some problems with my Arduino-System.
I want to send some information from my Arduino-Board to my Attiny45. I know it is possible to communicate in the other way. For example the Attiny send some temperature values to the master.
But that's not my problem. I want to send commands from my Arduino to the slaves and then they change the output ports LOW and HIGH.
Here is my master code:
#include <TinyWireM.h>
#include <USI_TWI_Master.h>
TinyWireM.begin();
TinyWireM.requestFrom(requestEvent);
void requestEvent(uint8_t slaveAddr)
TinyWireM.beginTransmission(2); //start of transmission
TinyWireM.send('F'); //transfers a char to the Slave
TinyWireM.endTransmission(); //end of transmission
TinyWireM.send('d'); //transfers a char to the Slave
Here the slave code:
//i2c Slave
#include <TinyWireS.h>
#include <Wire.h>
TinyWireS.begin(2); // join i2c bus with address #2
TinyWireS.onReceive(receiveEvent); // register event
pinMode(1 ,OUTPUT);
// function that executes whenever data is received from master
// this function is registered as an event, see setup()
void receiveEvent(int howMany)
while(TinyWireS.available())
char c = TinyWireS.receive(); // receive byte as a character
switch (c)
case 'd':
digitalWrite(1 ,LOW);
case 'F':
digitalWrite(1 ,HIGH);
The LED on port 1 should blink... But I just get error messages.
Here are the Keywords from the libraries
Syntax Coloring Map For TinyWireS
Datatypes (KEYWORD1)
Methods and Functions (KEYWORD2)
begin KEYWORD2
send KEYWORD2
available KEYWORD2
receive KEYWORD2
Instances (KEYWORD2)
TinyWireS KEYWORD2
Constants (LITERAL1)
Syntax Coloring Map For TinyWireM
begin KEYWORD2
beginTransmission KEYWORD2
endTransmission KEYWORD2
requestFrom KEYWORD2
send KEYWORD2
receive KEYWORD2
TinyWireM KEYWORD2
Thank you very much in advance.
