hello all, anybody had sucessfully use the arduino to connect to soy erriscon T610? i buy a t610 data cable, i can use it on PC successfully. Now i want to use it with arduino ,so i cut the cable,i found it is four lines, one connect the mobile pin 4 for TX ,One to pin5 for RX ,one to pin10 for GND ,one to pin3 . Someone told me only want the three lines ,so the pin3 is not useful. The next is i put Mobile pin4 -- arduino pin0, mobile pin5 to arduino pin1,mobile pin 10 to arduino GND. After all done ,i used the PC Terminal to send AT command, i cannot even type one character! i write some code to arduino , i only get the out information AT*EVD="82220356" ,the mobile is still nothing to happen. :-[ ,anybody can help me ? thanks.
// begin the serial communication
Serial.begin(4800);
printString("AT*EVD=\"82220356\"");
byte val;
// check if data has been sent from the computer
if (Serial.available()) {
// read the most recent byte (which will be from 0 to 255)
val = Serial.read();
// set the brightness of the LED
Serial.print(val);
hello,Orac,I just tried it as you said ,but i even cannot type "AT" in hyperTermial. it connected ,but cannot type anything character on the memo. maybe the problem is the arduino, not the mobile phone connectivity??
Now i have succeded in sending call in hyperlink after i attached "0D" on every AT Command. but now i meet another problem when i transmit command from arduino. it run and response ok but not call .
maybe you can help me again.
it's still very disappointed that i canot make it run. i think the code is right .Maybe the arduino not transmit the code to mobile. Even when i disconnect the mobile from the arduino, from the COM motitor software i can get the return code. when i transmit the same code on pc to arduono ,then arduono can transmit it to mobile;but when arduino directly transmit the code to mobile ,it not run. it's very surprising.
I need some help! I would like to know how could I dial phone number which is saved on the first place of my sim card.
The GSM is SE T610.I've tried ATD > SIM but it doesn't work.
