I want to use Arduino uno to intercept data of an external commercial board (the board is a car parking sensor board).
I want to sniffing data if parking sensors are activated and active it if necessary (with Arduino).
It Is possible?
Regards
It Is possible?
Regards
It may possible if you can capture the signals somehow, either by direct connection or by indirect measurement
Is the data digital (on/off) and individual for each sensor or is it more complicated in that a message may consist of several items of data for a sensor and the data for every sensor is transmitted along the same signal path ?
First, you should measure the signals you want to get with arduino. I mean voltage, frequency, waveform...
Once you know the characteristics of the signal it will be possible to determine if it's necessary to adapt and/or isolate them, if you have to process them as digital or analog, the minimum sample rate...
Do you have web links to the parking device?
Thanks.
The parking sensor are this:
I have installed this on front and i want to get if sensor are active and level of distance.
I have another problem. The sensors works only for 20seconds, and then stops. I must click the buttino to start. but I want to send signal to start automatic then this 20seconds (without button)
It Is possible? How can do this?
I m a developer but i have not experience with serial data etc.
Regards
Any ideas?
There is no simple set of instructions for sniffing unknown RF devices, and it can involve some specialist RF equipment. It can be difficult enough for those with a fair bit of experience in the field.
Perhaps ask in;
The page that you linked to has no technical details so it is difficult to offer advice
I did manage to find a manual for what looks like the device https://www.manualslib.com/manual/1591853/Metasystem-Active-Park-4-14.html?page=10#manual but it is incomplete so proved no help at all because despite the index having a Technical Details section, those pages are missing
What exactly do you want to sniff out and use ?
