Use of arrays
Hi
I am trying to make a dosing sketch for my aquarium. My issue is as follows:
Choose a set programme. I have a 2dose/day, 4dose/day, 8dose/day, 16dose/day and a 24dose/day. An allocated time has been set for each dose so it corresponds with time.
In order to not write thousands of lines of code I have tried to use arrays.
The first part of the code is to create my 5 arrays of the ON times of the dosing pump.
unsigned long 2Dose[2] = {0, 43200000};
unsigned long 4Dose[4] = {0, 21600000, 43200000, 64800000};
unsigned long 8Dose[8] = {0, 10800000, 21600000, 32400000, 43200000, 54000000, 64800000, 75600000};
unsigned long 16Dose[16] = {0, 5400000, 10800000, 16200000, 21600000, 27000000, 32400000, 37800000,
                          43200000, 48600000, 54000000, 59400000, 64800000, 70200000, 75600000, 81000000};
unsigned long 24Dose[24] = {0, 3600000, 7200000, 10800000, 14400000, 18000000, 21600000, 25200000, 28800000,
                          32400000, 36000000, 39600000, 43200000, 46800000, 50400000, 54000000, 57600000,
                          61200000, 64800000, 68400000, 72000000, 75600000, 79200000, 82800000};
unsigned long OffSet = 300000; //5MINUTE OFFSET
The second part was to create a generic function for the dosing pump
void Run2Dose (int pin,
               unsigned long time,       //Current time in millis
               unsigned long offset,     //Offset time in millis avoid clashing of dosing
              unsigned long start[],     //Start time in millis
               unsigned long period)     //On period time in millis
  for (int x = 0; x < 2; x++)
    if ((time + offset) + start[x] <= (time + offset) + start[x] + period)
      digitalWrite(pin, HIGH);
    else if ((time + offset) + start[x] >= (time + offset) + start[x] + period)
      digitalWrite(pin, LOW);
void Run4Dose (int pin,
  for (int x = 0; x < 4; x++)
void Run8Dose (int pin,
  for (int x = 0; x < 8; x++)
void Run16Dose (int pin,
  for (int x = 0; x < 16; x++)
void Run24Dose (int pin,
  for (int x = 0; x < 24; x++)
And the last part is the actual function
void RunDosers()
  ActualTime = (((hour()*3600) + (minute()*60) + second()) * 1000);
  if (Doser1Prog == 4)
    Run2Dose(DOS1, ActualTime, 0, 2Dose[x], D1P2);  //pin/time/ offset/start[]/period
    if (DOS1 == HIGH)
      LEDDOSER1.setColor(Blue);
      LEDDOSER1.on();
    else if (DOS1 == LOW)
      LEDDOSER1.setColor(Green);
      LEDDOSER1.on();
  else if (Doser1Prog == 5)
    Run4Dose(DOS1, ActualTime, OffSet, 4Dose[x], D1P4);  //pin/time/ offset/start[]/period
    if (DOS1 == HIGH)
      LEDDOSER1.on();
      LEDDOSER1.on();
  else if (Doser1Prog == 6)
    Run8Dose(DOS1, ActualTime, (OffSet * 2), 8Dose[x], D1P8);  //pin/time/ offset/start[]/period
    if (DOS1 == HIGH)
      LEDDOSER1.on();
      LEDDOSER1.on();
  else if (Doser1Prog == 7)
    Run16Dose(DOS1, ActualTime, (OffSet * 3), 16Dose[x], D1P16);  //pin/time/ offset/start[]/period
    if (DOS1 == HIGH)
      LEDDOSER1.on();
      LEDDOSER1.on();
  else if (Doser1Prog == 8)
    Run24Dose(DOS1, ActualTime, (OffSet * 4), 24Dose[x], D1P24);  //pin/time/ offset/start[]/period
    if (DOS1 == HIGH)
      LEDDOSER1.on();
      LEDDOSER1.on();
The issue is it does not compile. The following is the compile error
C:\Users\proie\Dropbox\ARDUINO\arduino 1.8.9\AquArt_Blynk_DoserTest\DOSERS.ino: In function 'void RunDosers()':
DOSERS:218:35: error: unable to find numeric literal operator 'operator"" Dose'
DOSERS:233:40: error: unable to find numeric literal operator 'operator"" Dose'
DOSERS:248:46: error: unable to find numeric literal operator 'operator"" Dose'
DOSERS:263:47: error: unable to find numeric literal operator 'operator"" Dose'
DOSERS:278:47: error: unable to find numeric literal operator 'operator"" Dose'
exit status 1
expected unqualified-id before numeric constant
can somebody please point me as to where I am going wrong please.
Thanks
You cannot use numbers as the first letter in a variable name, rename "2Dose" to "Dose2" or "_2Dose" - this applies to the other array names as well.
Ok, I will change that, what about the way I have used the arrays? if you note I have put a for loop in both the void Run2/4/16/24Dose and the void RunDoser statements.. is this correct?
Proietti:
If it works, yes - otherwise no.. :wink:
Your attempt at using arrays is laudable but not necessary because you do not need to store the of each dose, merely the period in milliseconds between doses, that is one period per dose scheme
Take a look at the BlinkWithoutDelay example. The blink period is equivalent to the period between doses and the changing of the state of the LED is when you would give a dose
As stated above there is no need for arrays.
Within the program you can directly calculate all the desired dose times or time intervals from a single constant: 86400 seconds per day.
N doses per day would be one dose every 86400/N seconds (multiply by 1000 for milliseconds), etc.
Thanks I will have a look at that. With regards to adapting blink without delay I did look at that but it wont do for my application. I will end up with 6 dosers all individually controlled and most importantly none of them will coincide with each other when dosing in other words there will be a 5 min gap between any dose, hence the idea to tie the dosing into programmes which use time to activate as opposed to millis
So, what is the problem ?
At worst you use 6 "timers" as used by BWoD or if the 5 minute gap is fixed then one "timer" and adjust the period according to the required gap
This kind of thing easily handles 1, 2, 3... 44, 45, 46, 47, 48... feedings a day.
  unsigned long interval =  (24UL * 60UL * 60UL * 1000UL) / FeedingsPerDay;
  static unsigned long lastFeedingTime;
  unsigned long currentTime = millis();
  if (currentTime - lastFeedingTime >= interval)
    // Time for a feeding!
    // NOTE: This would normally be "lastFeedingTime += interval;" which works best when the
    // interval is fixed.  In this case if you were three hours into a long interval and change the feeding
    // rate to 24 per day (one per hour) the feeder would feed three times immediately.  I think it is
    // safer to feed once now and again in an hour.
    lastFeedingTime = currentTime;
