Hi, I got here a part of the whole project’s code from around the web. This is from the VB.NET part.
Imports System.Net.Sockets
Imports System.Text
Public Class Form1
Dim tcpClient As New System.Net.Sockets.TcpClient()
Dim networkStream As NetworkStream
Dim KeyPressed As Integer
Private Function Arduino_Connect(ByVal IP As String, ByVal Port As Integer) As Boolean
tcpClient.Connect(IP, Port)
networkStream = tcpClient.GetStream()
If Not networkStream.CanWrite Or Not networkStream.CanRead Then
tcpClient.Close()
networkStream = Nothing
Return False
End If
Return True
End Function
Private Sub Arduino_Write(ByVal Output As String)
If Not IsNothing(networkStream) Then
Dim sendBytes As [Byte]() = Encoding.ASCII.GetBytes(Output)
Dim endByte As [Byte]() = {&HFE}
networkStream.Write(sendBytes, 0, sendBytes.Length)
networkStream.Write(endByte, 0, 1)
Else
MsgBox("ERROR")
End If
End Sub
This project communicates with the Arduino+Wishield in real time, what I mean is, when the user press a certain key in a keyboard, the arduino responses IMMEDIATELY.
I have attached here the whole source codes of the said project.
I have been studying and searching and searching for the easiest way (just like this) in making the Arduino with CC3000 communicate with C#/vb.net. What I got right now is the CC3000 library made by Adafruit, it is complicated for me but I’m doing my best to study it.
Is there anything, any library that I can use for CC3000 to implement the method used in this sample project?
Also, the vb.net code that I’ve posted above, is it applicable also when I use the CC3000 library made by adafruit?
Please help. Thanks.
Project.zip (155 KB)
