use transistor, to make arduino turn on relay. how to do this?
hi. i want the arduino uno, to energize a relay, that needs around 45ma to work (so close....) but i suppose that since the digital pins give only 40ma , they cant do that alone???
so i suppose i should use a transistor, to energize the relay from the 5v out of the arduino.
what type of transistor would i need to do that?? i have now idea how transistors work...
Something like this will do the job.You could use just one transistor ...
No the digital pins can give more if you connect them to a low enough impedance load.
The point is that you should not permit them to give more otherwise they will suffer damage. Even so 40mA is too high and is just a stress rating, try and not connect them to a load that demands more than 30mA.
what type of transistor should i use??? the relays have 90ohm coil resistance. how do i wire the transistor??
Any type of general purpose NPN transistor, all will be able to handle that small amount of current. I use a 2N2222 but anything, get the lowest cost one you can find.
According to the diagram, it has three wires, emitter - should go to ground, collector - should go to one end of the relay and base should go to a resistor value 1K to 10K. Other end of resistor to arduino pin. Other end of the relay to +5V.
Finally put a diode 1N4001 with the cathode (stripe end) to +5 and the anode to the transistor's collector.
See the first diagram of:-
http://www.thebox.myzen.co.uk/Workshop/Motors_1.html
thanks allot m8!!!
