How are you all doing, I have a project that use 4 water flow sensors. The problem is I only can use pin 2 to read pulse from sensor, other pins can't, they give back wrong pulse.
Thank you if you choose to help.
have a read of how-to-get-the-best-out-of-this-forum
in particular
are you using polling or interrupts to detect pulses from the flow sensors
Google your way to glory....
1.The sensor i'm using
YF-S401.pdf (57.2 KB)
2. Schematic
3.Code i'm using to test:
volatile int flow_frequency; // Measures flow sensor pulses
unsigned int l_hour; // Calculated litres/hour
unsigned char flowsensor = 2; // Sensor Input
unsigned long currentTime;
unsigned long cloopTime;
void flow () // Interrupt function
flow_frequency++;
pinMode(flowsensor, INPUT);
digitalWrite(flowsensor, HIGH); // Optional Internal Pull-Up
attachInterrupt(0, flow, RISING); // Setup Interrupt
sei(); // Enable interrupts
currentTime = millis();
cloopTime = currentTime;
void loop ()
// Every second, calculate and print litres/hour
if(currentTime >= (cloopTime + 1000))
cloopTime = currentTime; // Updates cloopTime
//Pulse frequency (Hz) = 7.5Q, Q is flow rate in L/min.
l_hour = (flow_frequency * 60 / 7.5); // (Pulse frequency x 60 min) / 7.5Q = flowrate in L/hour
flow_frequency = 0; // Reset Counter
Serial.print(l_hour, DEC); // Print litres/hour
Serial.println(" L/hour");
maybe try using InterruptOnChange for this...
Mega and Mega 2560 support change interrupts on the following pins: 10, 11, 12, 13, 14, 15, 50, 51, 52, 53, A8 (62), A9 (63), A10 (64), A11 (65), A12 (66), A13 (67), A14 (68), A15 (69).
Something like this maybe:
(Compiles, NOT tested!)
PORTB InterruptOnChange Connections:
PCINT0 (PB0 / 53)
PCINT1 (PB1 / 52)
PCINT2 (PB2 / 51)
PCINT3 (PB3 / 50)
PCINT6 (PB6 / 12)
PCINT7 (PB7 / 13)
const uint8_t flowsensor1 = 53, flowsensor2 = 52, flowsensor3 = 51; //assigned pin numbers to named variables
volatile uint16_t flow1_counter = 0, flow2_counter = 0, flow3_counter = 0; // Measures flow sensor pulsesz
uint8_t flowsensor1_state, flowsensor2_state, flowsensor3_state; //to hold last read pin value (for ISR ONLY)
uint32_t oldtime;
float L_Hour_Sensor1, L_Hour_Sensor2, L_Hour_Sensor3;
//initialise flow sensor counters
flow1_counter = flow2_counter = flow2_counter = 0;
flowsensor1_state = digitalRead(flowsensor1);
flowsensor2_state = digitalRead(flowsensor2);
flowsensor3_state = digitalRead(flowsensor3);
//Enable InterruptOnChange on pin 51,52,53
PCICR = _BV(PCIE0);
PCMSK0 = _BV(PCINT0) | _BV(PCINT1) | _BV(PCINT2);
oldtime = millis();
if (millis() - oldtime >= 1000) {
oldtime = millis();
//momentarily disable interrupts to avoid data corruption
noInterrupts();
uint16_t local_cnt1 = flow1_counter;
uint16_t local_cnt2 = flow2_counter;
uint16_t local_cnt3 = flow3_counter;
flow1_counter = flow2_counter = flow2_counter = 0; // Reset Counters
interrupts();
L_Hour_Sensor1 = ((local_cnt1 * 60) / 7.5); // (Pulse frequency x 60 min) / 7.5Q = flowrate in L/hour
L_Hour_Sensor2 = ((local_cnt2 * 60) / 7.5); // (Pulse frequency x 60 min) / 7.5Q = flowrate in L/hour
L_Hour_Sensor3 = ((local_cnt3 * 60) / 7.5); // (Pulse frequency x 60 min) / 7.5Q = flowrate in L/hour
// Print litres/hour from each sensor read
Serial.print(L_Hour_Sensor1, 2);
Serial.print(" L/hour, ");
Serial.print(L_Hour_Sensor2, 2);
Serial.print(L_Hour_Sensor3, 2);
ISR(PCINT0_vect) {
uint8_t data = PINB & PCMSK0; // read data and clear unused pins
if (digitalRead(flowsensor1) != flowsensor1_state) {
//update counter only if rising edge (ie HIGH) whenever ISR is triggered
if (flowsensor1_state) ++flow1_counter;
if (digitalRead(flowsensor2) != flowsensor2_state) {
if (flowsensor2_state) ++flow2_counter;
if (digitalRead(flowsensor3) != flowsensor3_state) {
if (flowsensor3_state) ++flow3_counter;
hope that helps....
