Using a 6v power supply to control a water pump
Im quite new to electronics in general so I'm sorry in advance.
So I would like to control a water pump,
Specs of the water pump:
Operating Voltage: 2.5-6V
Operating Current: 130~220mA
Driving Mode: DC, Magnetic Driving
The relay I would be using is a 1 channel 5V relay.
I would like to ask with the diagram below, if use a 6v power supply instead of the 9v battery, will the system still work? Or will it damage anything?
If so, what are some things that I need to make the system work?
6V battery like 4 AAs?
a 6v wall adapter
Then a diode across the pump will protect the relay and power supply
Okay thank you! Is that all I need?
Also may I ask what the diode is for?
To protect the relay and power supply from voltage spikes.
It's all you need.
Alright thank you!!
Also with this set-up, do I still a power source to power the arduino separately?
Yes.
You can power the Uno with 7 to 12V connected to the barrel jack or Vin or 5V connected to to the USB connector.
Since I only have a 9v and 6v adapter, can I use the 9v for the pump and 6v for the arduino?
6V is not high enough to power Arduino through VIN or barrel jack, needs at least 7V. Power Arduino with 9V through VIN pin or barrel jack, pump with 6V adapter.
