I wanted to control a Menu, which is shown on a display by using a rotary encoder for navigation.
The display works perfectly, as well as the rotary encoder.
that is if they are in seperate sketches.
Once I try to read the Pin of the rotary encoder inside the sketch which controls the display, the rotary encoder no longer works.
Here is the code of the sketch, thanks in advance!:
#include <Arduino.h>
#include <U8g2lib.h>
#include <SPI.h>
#include <Wire.h>
#define rotary_pin_A 2
#define rotary_pin_B 3
#define rotary_pin_Push 4
int rotary_state;
int rotary_last_state;
int m1p[4] = {25, 3, 24, 24};
int m2p[4] = {53, 3, 24, 24};
int m3p[4] = {80, 3, 24, 24};
int m4p[4] = {25, 28, 24, 24};
int m5p[4] = {53, 28, 24, 24};
int m6p[4] = {80, 28, 24, 24};
int current_mode = 1;
int current_brightness = 50;
int current_color = 0;
int current_band_level = 1;
U8G2_SH1106_128X64_NONAME_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);
void setup(void){
pinMode(rotary_pin_A, INPUT);
pinMode(rotary_pin_B, INPUT);
pinMode(rotary_pin_Push, INPUT);
rotary_last_state = digitalRead(rotary_pin_A);
u8g2.begin();
void loop(void){
rot_state = digitalRead(rotary_pin_A);
Serial.println(rotary_state);
// I think from now on the code is irrelevant for this, since it only controls the display
u8g2.firstPage();
do {
drawConstantLayout();
drawModeFrame();
drawBrightnessIndicator();
drawColorSlider();
drawBandSelector();
} while (u8g2.nextPage());
void drawConstantLayout() {
// Initial Layout Setup
u8g2.drawFrame(0, 0, 128, 64);
// Brightness Seperator
u8g2.drawLine(22, 0, 22, 64);
// Color Seperator
u8g2.drawLine(22, 54, 106, 54);
// Lines Seperator
u8g2.drawLine(106, 0, 106, 64);
// Brightness Indicator
u8g2.drawRFrame(6, 15, 10, 45, 1);
// Lamp Symbol --start
u8g2.drawPixel(7, 8);
u8g2.drawPixel(8, 7);
u8g2.drawPixel(9, 5);
u8g2.drawPixel(9, 4);
u8g2.drawPixel(10, 5);
u8g2.drawPixel(10, 4);
u8g2.drawPixel(10, 3);
u8g2.drawPixel(11, 5);
u8g2.drawPixel(11, 4);
u8g2.drawPixel(11, 3);
u8g2.drawPixel(12, 5);
u8g2.drawPixel(12, 4);
u8g2.drawPixel(13, 5);
u8g2.drawPixel(13, 4);
u8g2.drawPixel(12, 3);
u8g2.drawPixel(11, 8);
u8g2.drawPixel(11, 7);
u8g2.drawPixel(14, 7);
u8g2.drawPixel(15, 8);
// Lamp Symbol --end
// O --begin
u8g2.drawPixel(26, 60);
u8g2.drawPixel(27, 61);
u8g2.drawPixel(28, 61);
u8g2.drawPixel(29, 61);
u8g2.drawPixel(30, 60);
u8g2.drawPixel(30, 59);
u8g2.drawPixel(30, 58);
u8g2.drawPixel(29, 57);
u8g2.drawPixel(28, 57);
u8g2.drawPixel(27, 57);
u8g2.drawPixel(26, 58);
u8g2.drawPixel(26, 59);
// O --end
// Color Slide Line
u8g2.drawLine(33, 60, 98, 60);
u8g2.drawPixel(33, 61);
u8g2.drawPixel(98, 61);
// R --begin
u8g2.drawPixel(104, 61);
u8g2.drawPixel(104, 60);
u8g2.drawPixel(103, 59);
u8g2.drawPixel(102, 59);
u8g2.drawPixel(101, 59);
u8g2.drawPixel(101, 60);
u8g2.drawPixel(101, 61);
u8g2.drawPixel(104, 58);
u8g2.drawPixel(103, 57);
u8g2.drawPixel(102, 57);
u8g2.drawPixel(101, 57);
u8g2.drawPixel(101, 58);
// R --end
// Bands --begin
u8g2.drawFrame(111, 5, 13, 6);
u8g2.drawFrame(111, 13, 13, 6);
u8g2.drawFrame(111, 21, 13, 6);
u8g2.drawFrame(111, 29, 13, 6);
u8g2.drawFrame(111, 37, 13, 6);
u8g2.drawFrame(111, 45, 13, 6);
u8g2.drawFrame(111, 53, 13, 6);
// Bands --end
// Only-Light-Mode Logo --begin
u8g2.drawLine(33, 5, 40, 5);
u8g2.drawLine(32, 6, 32, 7);
u8g2.drawLine(31, 8, 31, 10);
u8g2.drawLine(41, 6, 41, 7);
u8g2.drawLine(42, 8, 42, 10);
u8g2.drawLine(32, 11, 41, 11);
u8g2.drawLine(30, 11, 29, 12);
u8g2.drawLine(29, 13, 31, 15);
u8g2.drawPixel(32, 15);
u8g2.drawLine(43, 11, 44, 12);
u8g2.drawLine(44, 13, 42, 15);
u8g2.drawPixel(41, 15);
u8g2.drawLine(33, 16, 40, 16);
u8g2.drawLine(31, 17, 28, 24);
u8g2.drawLine(35, 18, 34, 24);
u8g2.drawLine(38, 18, 39, 24);
u8g2.drawLine(42, 17, 45, 24);
// Only-Light-Mode Logo --end
// Simple Visualizer Logo --begin
u8g2.drawLine(55, 24, 63, 24);
u8g2.drawLine(55, 22, 55, 14);
u8g2.drawLine(57, 22, 57, 19);
u8g2.drawPixel(59, 22);
u8g2.drawLine(61, 22, 61, 21);
u8g2.drawLine(63, 22, 63, 20);
u8g2.drawLine(59, 14, 68, 14);
u8g2.drawLine(66, 12, 68, 14);
u8g2.drawLine(66, 16, 68, 14);
u8g2.drawFrame(71, 7, 3, 18);
u8g2.drawLine(72, 14, 72, 23);
// Simple Viualizer Logo --end
// Ray Visualizer Logo -- begin
u8g2.drawLine(82, 24, 90, 24);
u8g2.drawLine(82, 22, 82, 14);
u8g2.drawLine(84, 22, 84, 19);
u8g2.drawPixel(86, 22);
u8g2.drawLine(88, 22, 88, 21);
u8g2.drawLine(90, 22, 90, 20);
u8g2.drawLine(86, 14, 95, 14);
u8g2.drawLine(93, 12, 95, 14);
u8g2.drawLine(93, 16, 95, 14);
u8g2.drawPixel(100, 5);
u8g2.drawRFrame(99, 6, 3, 5, 1);
u8g2.drawPixel(100, 11);
u8g2.drawRBox(99, 12, 3, 5, 1);
u8g2.drawPixel(100, 17);
u8g2.drawRFrame(99, 18, 3, 5, 1);
u8g2.drawPixel(100, 23);
// Mode selector test
/// Just Animation Stuff
void toggleMode(){
if (current_mode != 6){
current_mode = current_mode + 1;
current_mode = 1;
void toggleBrightness(){
if(current_brightness != 100){
current_brightness = current_brightness + 10;
current_brightness = 0;
void toggleColor(){
if(current_color != 100){
current_color = current_color + 5;
current_color = 0;
void toggleBandLevel() {
if(current_band_level != 13) {
current_band_level = current_band_level + 1;
// End of Animation Stuff
void drawModeFrame(){
switch (current_mode){
case 1:
u8g2.drawFrame(m1p[0], m1p[1], m1p[2], m1p[3]);
case 2:
u8g2.drawFrame(m2p[0], m2p[1], m2p[2], m2p[3]);
case 3:
u8g2.drawFrame(m3p[0], m3p[1], m3p[2], m3p[3]);
case 4:
u8g2.drawFrame(m4p[0], m4p[1], m4p[2], m4p[3]);
case 5:
u8g2.drawFrame(m5p[0], m5p[1], m5p[2], m5p[3]);
case 6:
u8g2.drawFrame(m6p[0], m6p[1], m6p[2], m6p[3]);
default:
u8g2.drawFrame(30, 30, 29, 29);
void drawBrightnessIndicator() {
// Max heights: 15 - 60
int true_height = 59 - (current_brightness * 0.44);
u8g2.drawLine(6, true_height, 15, true_height);
void drawColorSlider() {
// Max widths: 33 - 98
int true_width = 33 + current_color * 0.65;
u8g2.drawLine(true_width, 58, true_width, 62);
void drawBandSelector() {
if((current_band_level / 7.0) > 1) {
u8g2.drawBox(120, 7 + ((current_band_level - 8) * 8), 2, 2);
u8g2.drawBox(120, 15 + (( current_band_level - 8) * 8), 2, 2);
u8g2.drawBox(120, 7 + ((current_band_level - 1) * 8), 2, 2);
