Using a SSR for power switching
I am considering using a SSR to control the output from an SMPS, however I do not know how to use one.
Regarding the picture below, am I right to assume that applying voltage to pin 1 turns on the relay, with 2 returned to ground. Additionally, am I right to assume that pin 3 is connected to the output of the SMPS, with 4 connected to the input of my circuit?
Additionally, regarding switching of the relay, can I simply just connect a switch between the SMPS output and pin 1 to switch the load on and off?
Help would be appreciated.
(This is intended for switching DC loads up to 1.5A at 12V).
With the assumption that your SMPS means Switch Mode Power Supply, then yes to all the questions.
The input to a SSR, DC or AC, is a LED that is turned on or off to control the relay. The output on a DC relay is a MOSFET to turn the second circuit on or off.
Thank you for the response. Do I need a resistor in series at pin 1 to limit how much current flows into the switch? If so, how big?
It depends on the exact part number you are using.some types do need one but with most you do not. Look at the data sheet of the part you have.
