I need one analog input and four digital outputs. I had to address chip pin #3 as pin=2 to get it to use analog in. It would not let me delare pin=A4. How do I now use chip pin #7 which should be pin=2
*R
*R
// ATMEL ATTINY45 / ARDUINO
// Ain0 (D 5) PB5 1| |8 Vcc
// Ain3 (D 3) PB3 2| |7 PB2 (D 2) Ain1
// Ain2 (D 4) PB4 3| |6 PB1 (D 1) pwm1
// GND 4| |5 PB0 (D 0) pwm0
Looks like A1 to me.
the Attiny85 took PB2. Would not let ne by with A1.
Hi
I had the same need (4x digital and 1x analog) for a set of RC aircraft navigation lights based on ATtiny85. I used pin2 as the analog, and addressed it as 3. The definitions block follows:
const int wingTips = 0; // IC leg 5; red and green 3mm LED navigation lights for wingtips
const int LDRpower = 4; // IC leg 3; power for LDR, turned off if it's daylight
const int lightSensor = 3; // IC leg 2; LDR sensor reading
const int redBeacon = 1; // IC leg 6; flashing red 3mm LED on tail
const int headlight = 2; // IC leg 7; 2x 5mm white LEDs for landing lights
lightSensor in this sketch is a LDR, addressed using analogRead().
Hope that helps, Geoff
there is no port A on the 85, if you need to use analog use analogRead(1)
just like on the normal arduino, analog input 1 is actually digital pin 15 and avr port C1
