Using an Arduino as a PS/2 Keyboard
All the research I've done has shown me a lot of people converting PS/2 to USB with Arduino, and even searching for anyone trying to make a PS/2 keyboard has given me the same results. It is an old interface so I can understand this, but even now a lot of gaming and lower-end motherboards come with PS/2 for wither the latency or legacy purposes.
I'd just like to know if it's even possible to do this or if there's a better way to do it without a microcontroller.
#include "ps2dev.h" // to emulate a PS/2 device
// Orange = 2
// Blue = 3
// Red = 5V (3 in)
// Black = GND (4 in)
// EXT Power, USB for COM only
PS2dev keyboard(3,2); // PS2dev object (2:data, 3:clock)
int enabled = 0; // pseudo variable for state of "keyboard"
boolean serialConnected = false;
int incomingByte = 0;
void ack() {
  //acknowledge commands
  while(keyboard.write(0xFA));
int kbdCmd(int command) {
  unsigned char val;
  switch (command) {
  case 0xFF: //reset
    ack();
    //the while loop lets us wait for the host to be ready
    while(keyboard.write(0xAA)!=0);
  case 0xFE: //resend
    ack();
  case 0xF6: //set defaults
    //enter stream mode
    ack();
  case 0xF5: //disable data reporting
    //FM
    enabled = 0;
    ack();
  case 0xF4: //enable data reporting
    //FM
    enabled = 1;
    ack();
  case 0xF3: //set typematic rate
    ack();
    keyboard.read(&val); //do nothing with the rate
    ack();
  case 0xF2: //get device id
    ack();
    keyboard.write(0xAB);
    keyboard.write(0x83);
  case 0xF0: //set scan code set
    ack();
    ack();
  case 0xEE: //echo
    //ack();
    keyboard.write(0xEE);
  case 0xED: //set/reset LEDs
    ack();
    ack();
void connectHost() {
  while (Serial.available() <= 0) {
    Serial.print('A');   // send a capital A
    delay(300);
  pinMode(13, OUTPUT);
  //establish serial connection with host
  // establish ps/2 connection with target
  while(keyboard.write(0xAA)!=0){
    digitalWrite(13, HIGH);
    digitalWrite(13, LOW);
  delay(100);
  connectHost();
  Serial.println("\nSerial Host Connected");
  Serial.flush();
  unsigned char c;
  if( (digitalRead(3)==LOW) || (digitalRead(2) == LOW)) {
    if(digitalRead(3)==LOW){
      Serial.println("pin 3  is LOW");
      Serial.println("pin 2 is LOW");
    while(keyboard.read(&c));
    kbdCmd(c);
    Serial.print("Target: 0x");
    Serial.println(c, HEX);
  else {//if host device wants to send a command:
    //echo ASCII code from terminal and write to ps/2
    if(Serial.available() > 0) {
      incomingByte = Serial.read();
      keyboard.write(incomingByte);
      Serial.print("Host: 0x");
      Serial.print(incomingByte, HEX);
      Serial.print(" ");
      Serial.print(incomingByte);
      Serial.print(" ");
      Serial.println(incomingByte, BIN);
On this page at the very bottom there is a listing of a possible initialization sequence. Start by comparing this initialization to that one.
http://www.computer-engineering.org/ps2keyboard/
It can be used to act as a mouse or a keyboard.
http://playground.arduino.cc/ComponentLib/Ps2mouse
//KBD stuff
unsigned char c;  //char stores data recieved from computer for KBD
//Sonar stuff
const int numReadings = 5;   // set a variable for the number of readings to take
int index = 0;                // the index of the current reading
int total = 0;                // the total of all readings
int average = 0;              // the average
int oldAverage = 0;           // the old average
int echoPin = 6;              // the SRF05's echo pin
int trigPin = 7;              // the SRF05's init pin
unsigned long pulseTime = 0;  // variable for reading the pulse
unsigned long distance = 0;   // variable for storing distance
void ack()
int keyboardcommand(int command)
  unsigned char val;
  switch (command)
  case 0xFF: //reset
    ack();
  case 0xFE: //resend
    ack();
    //enter stream mode
    ack();
    //FM
    enabled = 0;
    ack();
    //FM
    enabled = 1;
    ack();
    ack();
    ack();
    ack();
    ack();
    ack();
  case 0xEE: //echo
    //ack();
    ack();
    ack();
  // send the keyboard start up
  delay(10);
  // make the init pin an output:
  pinMode(trigPin, OUTPUT);
  // make the echo pin an input:
  pinMode(echoPin, INPUT);
  // initialize the serial port:
  // loop for a number of readings on the SRF-05 to get an average to smooth the results. Much like all my other examples
  for (index = 0; index<=numReadings;index++)
    digitalWrite(trigPin, HIGH);
    delay(1);
    digitalWrite(trigPin, LOW);
    pulseTime = pulseIn(echoPin, HIGH);
    distance = pulseTime/58;
    total = total + distance;
    delay(5);
  // store the previous reading
  oldAverage = average;
  // store the current reading
  average = total/numReadings;
  // debug to check for spikes in the sensor etc..
  Serial.println(average);
    while(keyboard.read(&c)) ;
    keyboardcommand(c);
    // now the fun part...
    // if my distance is less than 5...
    if (average <=5)
      int x = 0;
      if(x<=5)  //how many times to press tab
        Serial.println("TAB+ALT");
        keyboard.write(0x11); //send ALT
        keyboard.write(0x0D); //then send Tab
        keyboard.write(0xF0);  //tab break
        keyboard.write(0x0D);  //...
        delay(700); // wait so doesnt tab too fast
        if(x<=5)
          keyboard.write(0x0D); //send another Tab
          delay(700);
      else //x is nolonger <=5 must be 6, set x to 0, and end all keys
        x=0; //reset tab counter
        keyboard.write(0xF0);  //alt break
        keyboard.write(0x11);  //...
      x++; //add 1 to tab counter
    else // otherwise if my hand is higher
      // check to see if my hand is in the registered space above the sensor
      if (average <=20 && average >=10 && oldAverage >=10)
        // the below statement is our sensitive the readings are so if the current and previous readings are different with a tolerance of +/
        //we can look at the direction of movement
        if ((average != oldAverage) && (average+1 != oldAverage) && (average-1 != oldAverage))
          // if the current reading is higher than the previous, then my hand is moving upwards
          if (average > oldAverage)
            Serial.println("Sound up");
            keyboard.write(0xE0); //make volume +
            keyboard.write(0x32); //...
            keyboard.write(0xE0); //break
            keyboard.write(0xF0); //...
            delay(150);  //wait so it doesnt change volume rapidly
            // otherwise if it is below then my hand is moving downwards
            if (average < oldAverage && oldAverage <=20)
              Serial.println("Sound down");
              keyboard.write(0xE0); //make volume -
              keyboard.write(0x21); //...
              delay(150);
          // otherwise my hand must be stationary so check where it is.
          // if my hand is stationary between 10 and 15 cms away from the sensor
          if (average >= 10 && average <=15)
            Serial.println("Copy");
            keyboard.write(0x14); //make CNTRL
            keyboard.write(0x21); //make 'c'
            keyboard.write(0xF0); //break 'c' break
            keyboard.write(0xF0); //break FO capital o) CNTRL break
            keyboard.write(0x14); //...
            delay(250);
            // if my hand is a bit higher up...
            if (average >= 16 && average <=20)
              Serial.println("Paste");
              keyboard.write(0x2A); //make 'v'
              keyboard.write(0xF0); //break 'v' break
              keyboard.write(0x2A); //...
              delay(250);
  // clear our index and total for the next reading just in case
  if (index >= numReadings)
    index = 0;
    total = 0;
thnikk:
If you want to do it without a microcontroller, you can do it with FPGA.
You can buy a PS2 to USB converter for a lot less (about 1/4 of the Uno) than the price of an Arduino! It takes both the keyboard and the mouse.
If you still want to DIY it the you need a Leonardo or the Yun.
Mark
holmes4:
You can buy a PS2 to USB converter for a lot less (about 1/4 of the UNO) than the price of an Arduino! It takes both the keyboard and the mouse.
I have a funny suspicion that you understood the request backwards.
Mind you, that's not surprising!
