The application is, to all intents and purposes, drone related
Hi, I have an MPU6050 and I'm trying to understand how I use the gyroscope with the adafruit library. I'm happily able to read out accelerometer data and I have an Uno beeping with different tones when it is tilted on X/Y/Z planes
When it comes to the gyro, I can read the data which, as I understand it, gives me X/Y/X acceleration in radians per second squared. I thought I would be able to just take the time between two readings and then know how many radians (and therefore degrees) moved.
I keep stumbling into various I2C demos without the adafruit library doing arctan etc. for pitch/roll/yaw but it feels like I should be able to use the adafruit library to do this more easily. Is anybody able to give some pointers?
Thanks
James
//-Include files--------------------------------------------------------------------------------------------------------------------------------------------------------------------------
#include <Adafruit_MPU6050.h> //Hardware functions specific to the 6050
#include <Adafruit_Sensor.h> //Unified sensor abstration layer
#include <Wire.h> //I2C interface
//-Globals--------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
Adafruit_MPU6050 MPU6050; //MPU6050 object
int X_POS = 0;
int Y_POS = 0;
int Z_POS = 0;
long OLD_TIME = 0;
void setup(void)
//Wait for the serial port to become available
while (!Serial)
//Shouldn't enter this loop normally
delay(10);
//Try to configure the gyro etc.
if (SetupAccelerometer() == false)
//Enter our infinite loop
DeadMPU6050();
//-Sets up the MPU6050--------------------------------------------------------------------------------------------------------------------------------------------------------------------
bool SetupAccelerometer()
bool ReturnValue = false;
//If we can't talk to the hardware
if (MPU6050.begin() == false)
//Display a debug message, we will return false
Serial.println("MPU6050 failure");
//Range in +/- 'G', 2 is the default which is most sensitive MPU6050_RANGE_2_G, MPU6050_RANGE_4_G, MPU6050_RANGE_8_G, MPU6050_RANGE_16_G
MPU6050.setAccelerometerRange(MPU6050_RANGE_2_G);
//Range in degrees per second, 250 is the default, smaller is more sensitive, MPU6050_RANGE_250_DEG, MPU6050_RANGE_500_DEG, MPU6050_RANGE_1000_DEG, MPU6050_RANGE_2000_DEG
MPU6050.setGyroRange(MPU6050_RANGE_250_DEG);
//Digital low pass filter for smoothing, 260 disables, removes high frequency noise, MPU6050_BAND_260_HZ, MPU6050_BAND_184_HZ, MPU6050_BAND_94_HZ, MPU6050_BAND_44_HZ, MPU6050_BAND_21_HZ, MPU6050_BAND_10_HZ, MPU6050_BAND_5_HZ
MPU6050.setFilterBandwidth(MPU6050_BAND_21_HZ);
//Flag that it worked OK
ReturnValue = true;
return ReturnValue;
sensors_event_t Accelerometer, Gyroscope, Temperature;
MPU6050.getEvent(&Accelerometer, &Gyroscope, &Temperature);
if (Accelerometer.acceleration.x == 0 && Accelerometer.acceleration.y == 0 && Accelerometer.acceleration.z == 0 && Gyroscope.gyro.x == 0 && Gyroscope.gyro.y == 0 && Gyroscope.gyro.z == 0)
DeadMPU6050();
//We're crashing now, the Z axis doesn't have 9.8 m/S of gravity pulling on it
if (Accelerometer.acceleration.z < 7)
//Serial.println ("Z axis -");
Beep(100, 300);
if (Accelerometer.acceleration.x > 3)
//Serial.println ("X axis +");
Beep(2500, 50);
else if (Accelerometer.acceleration.x < -3)
//Serial.println ("X axis -");
Beep(2000, 50);
if (Accelerometer.acceleration.y > 3)
//Serial.println ("Y axis +");
Beep(1500, 50);
else if (Accelerometer.acceleration.y < -3)
//Serial.println ("Y axis -");
Beep(1000, 50);
long NewTime = micros();
if (OLD_TIME != 0)
//Multiply the change in time between samples by the number of degrees per second moved (/1000 to convert from mS to S)
X_POS = X_POS + (((NewTime - OLD_TIME) * (Gyroscope.gyro.x * RAD_TO_DEG ))/1000000);
Y_POS = Y_POS + (((NewTime - OLD_TIME) * (Gyroscope.gyro.y * RAD_TO_DEG ))/1000000);
Z_POS = Z_POS + (((NewTime - OLD_TIME) * (Gyroscope.gyro.z * RAD_TO_DEG ))/1000000);
OLD_TIME = micros();
delay(200);
//-Infinite loop with error messages if the MPU6050 is dead or dies-----------------------------------------------------------------------------------------------------------------------
void DeadMPU6050()
//Stay here forever, alarming
while (1)
Beep(BUZZER_LOW_FREQUENCY, 300);
delay(100);
Beep(BUZZER_HIGH_FREQUENCY, 300);
Serial.println ("No MPU6050 found!");
