Hi! Would like your thoughts on interfacing an off-the-shelf scale with an Arduino.
Mainly feasibility & general approach, but all ideas are welcome!
Context
I'm new to Arduino, low-medium experience programmer, built plenty of mechanical contraptions.
Planning to build a semi-automated machine.
The part I'm stuck on is weighing.
I have a 50 g ±1 mg ebay scale which would work fine (combined error 5-8% according to my tests).
How do I get the data from the scale (or its load cell) into the Arduino?
Approach: Jury Rigging the LCD Output
The display is a 7-segment LCD with 6 positions, and a decimal point (DP).
The interface is 14 unmarked leads. I'm assuming that's just a multiplexed 7-segment & DP, and one ground for each number position.
Is it possible to connect these 14 leads to the arduino, and have the Arduino read the signals meant for the 7-segment display as a data input?
I've looked around, but haven't found anyone attempting it. Is it feasible at all (with some work of course), or should I skip this approach?
Approach: HX711
Hx711 interfaces an Arduino to a load cell.
Would this work with the load cell from an off-the-shelf scale?
Sounds more like a standard common anode or common cathode display, if common anode it can be driven by a TM1637.
Six of those pins will be common for the individual digits; the other eight are for the segments a-g and DP.
