Hi all,
I have four manual switches in a ~100vDC circuit and I would love to automate them with Arduino. They need to be switched in a certain sequence, and I need to measure and compare the voltage at two points in the circuit to drive some of the logic.
Edit: This is ALL DC voltage only, no AC.
The logic side I think I'm ok with, but there's a couple of details which I could really use
some advice on.
I've tentatively got an Espressif ESP32-S3-DevKitC-1-N8R8 board in mind, though I'm seeing the ADC unit on this board is not very fast/accurate. Which may factor in to the voltage measurement.
I've posted the pseudocode of my logic at the end.
The questions I have are:
Three of the devices I'm switching are normally open DC contactors. They use 12v for the actuator coil and see an inrush current of 3.8A. Holding current drops to 0.2A via a built-in coil economizer. I've been looking at TIP120 transistors and also at some solid state relays as a possible way to switch higher voltages and current using the Arduino's output pins.
Is a transistor like a TIP120 the best way to go for this? Will it generate significant heat if it's 'on' the whole time? I don't want to use a mechanical relay.
Is a solid state relay basically a transistor switch? I see they also can require heatsinks.
For either of these options, how do I calculate the type and value of the resistor needed on the Arduino's digital output pin that connects to the transistor?
I've read that the espressif ESP-32 board's ADC is not very fast nor precise. What's the ideal way to accurately measure voltage at two points in the circuit? We'd be looking at around 90-130v DC range and a significant amount of current. I would also need two of the measurement devices and need them to be accurate enough to compare readings within about 0.1v or better. Are there shields or any external board I could use to 'feed' the Arduino the measured value? Or what's my best option here?
additional info for Q4 - the battery is 100vdc, 60Ah, 400A cont. current/700A peak. If I had to use voltage divider circuits to measure, will I be making some large resistors very hot? I'd like to minimize heat wastage where possible.
I'm definitely not married to the Espressif ESP-32 board if a more suitable option exists. Reliability and accuracy are the two important factors.
I'm using a solid state relay for the last switching output. This one sees full voltage (~100vdc) but very low current. How do I calculate the arduino output pin resistor I'd need please? Panasonic AQZ107D
https://industry.panasonic.com/global/en/products/control/relay/photomos/number/aqz107d
Thanks ever so much for any guidance on this.
Psuedocode logic for the program:
function 1 (boot up)
power applied
write 'waiting' to screen
momentary switch pressed once
switches device 1 on
short delay
switches device 2 on
reads voltage 1
reads voltage 2
while loop: voltage 2 is less than 90% of voltage 1
switch on device 3
short delay
switch device 2 off
switch solid state relay 4 on
write 'ready' to screen
leave device 1 and device 3 switched on the entire time it's running.
function 2 (shutdown)
switch solid state relay 4 off
switch device 1 off
short delay
switch device 3 off
write 'power off' to screen
